Question about T-Mobile Sidekick II
HELP I WENT 2 CAGRGE MY PHONE AND PLUGED IN THE WRONG CHARGER IT HAD 120V. AND I THINK I BLOW THE BATTERY BBUT AM NOT REALLY SURE... I PLUGGED IN THE REAL CHARGER AND NOTHING HAPPENED ! PLEASE HELP ME I REALLY REALLY NEED IT! I CAN BE EMAIL AT: JERELL94@HOTMAIL.COM
1.Tryed switching it on?
2.Get a new battery of the internet and ask t-mobile to put it in.
3.Reset your device by twisting your phine anti-clock wises and insert a needle into the hole.
3.Contact T-Mobile.
Posted on May 31, 2008
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
I have a #20 charger inverter on my sailboat. It has worked fine for several years. This winter, I replaced the battery bank with 4 Trojan T-105. Batteries are fully charged, new battery wiring and...
Without more information, it could be a number of things. For starters, you might try disconnecting the ground wire to see if that makes any difference. The Xantrex Owner's/Installation Manual says specifically not to connect the inverter's negative *battery cable* to the vessel ground, but if the unit's housing and the negative cable share a common ground somewhere inside the unit, that would be the same thing. The T-105s are great batteries, but since they are 6V, make sure you rewired them correctly, i.e. a pair in series (12V) wired in parallel with the other pair for 450 AH total. Recheck all your battery connections and make sure you didn't blow the inline battery fuse in case you inadvertently made a momentary wrong connection during the new battery installation.
Apr 27, 2010 | Xantrex Technology Heart Freedom 30...
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Phone went dead while I was talking....
try to use a new battery if it works i think your old battery has a problem.
thanks,
Jun 23, 2009 | Cell Phones
Hello, my godmom just purchased a Brand new Blackberry Curve phone.When the saler put the battery in the phone, it didn't power on and she said that the battery was not charged and that we had to charge...
Its very hard to pinpoint the problem from your few descriptions. However since the light came on it mostly means the charger should be okay. As for the phone, if the battery is really dead, it sometime takes up to 30 minutes before it shows that it is charging. SO leave it plugged in for some time to see what happenes. If it did not come on after that then the phone is bad. Just to make eveything sure, you can also try any other MINI USB charger or a simple MINI USB cord to the computer to charge the phone with as well. They all work on the Blackberry
May 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
Nitendo ds lite
Ive done this.......
1.Blow into end of DS charger...
2.Dip end into salt.*DO NOT STIR IT AROUND...dip in and pull out*
3.tap end onto a hard surface LIGHTLY untill excess salt is out/off of tip...
4.Blow into end/tip of charger again...
5.Plug in your charger...
***WHEN PERFORMING THE STEPS ABOVE MAKE SURE CHARGER IS PLUGGED-IN TO OUTLET***
Oct 11, 2008 | Nintendo DS Lite Console
Acer aspire 3500 wont hold charge or turn on
I had to buy an new ac/dc plug piece off of ebay (cost only like $3 bucks) to sodder onto the mother board of my Acer. Somehow the little plastic/metal piece you plug into your computer comes off the mother board really easy. Acer wanted me to purchase a whole new mother board (at frigging $350), which, frankly wasn't an option. So I bought the little plug gizmo, soddered it on, and I'm doing good now.
Apr 09, 2008 | Computers & Internet
Motorolai836
It's the mini coin cell battery in the rear housing. You must take it to a service center
Nov 17, 2007 | Motorola Mobility i836 Cellular Phone
Charging problem
check the base connection this can be damaged if the charger is inserted the wrong way.
If this has happened then you will need a tech to repair it.
If it is not this then I think your battery has died
Nov 16, 2007 | Samsung SGH-E370 Cellular Phone
T-Mobile Sidekick II Logo
53 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
