Question about Toshiba Satellite M35X-S111 Notebook
PROBLEM WITH MY SATELLITE M35X-S111
WHEN I CUT MY COMPUTER ON, THE FAN WILL RUN BUT THE SCREEN SHOWS NOTHING.. WHAT DO I DO??
  • 458 Answers
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
Posted on Jun 04, 2008
No sound or audio drives or hardware
Hi, Please visit the below website to download the audio drivers for your computer:- http://www.drivershq.com/Drivers/TOSHIBA/SATELLITE/M35X-S111/4183/9941/10762/44239/ModelDrivers.aspx Please download and install the audio driver and you should have the sound on your computer. Thank you for your time and best wishes for your effort.
Jan 11, 2011 | Toshiba Satellite M35X-S111 Notebook
After fixing power jack problem secreen will not lit
toshiba satellite M35X-S111
After solving the jack problem.
when I click on the start button I hear the fan voise but there is nothing on the moniter and no sound.
When I remove the connection between the start button and the mother board and put it again it works two times and then the problem started again.
The computer may work random at sometimes.
Is the problem in the small board and the cable which between the start button and the mother board ?
If yes how to purchase it
Dec 12, 2009 | Toshiba Satellite M35X-S111 Notebook
Had laptop sitting in lap and turned body briefly lap top went off and will not power up. the fan runs but will not power up. screen is blank
you may have hit the sleep or standby button. Try turning the pc off by holding down the power button untill you hear the fans stop. then power up as usual.
Nov 08, 2009 | Toshiba Satellite M35X-S111 Notebook
Power on but no screen oor hard disk motion
Hello there:
i would suggest using a spare monitor and connect the cord that would normally go into a computer and connect it to the laptop and then plug in the power cord for the monitor and turn on the computer if this works and everything is ok then you know that the laptop screen may be faulty or there may be a loose connection somewhere ok?
best regards michael
Sep 11, 2009 | Toshiba Satellite M35X-S111 Notebook
My M35X-S111 keeps shutting down
More than likely it is overheating you can buy a can of compressed air and blow it out if you dont have a compressor that should be done at least every 6 months
Aug 06, 2008 | Toshiba Satellite M35X-S111 Notebook
No power up on Satellite M35X-s111
Heres the fix:
This requires access to the cpu and heatsink, remove the keyboard and palmrest to access the motherboard, I think you have to remove the screen too. Remove the heatsink and cpu. Reseat the cpu, heres the kicker, press firmly on the center of the cpu while turning the locking screw. Pressing the cpu hard, allows the locking mechinism to get a good bite. Turn the locking screw hard into the end of the turn. Hook up the heatsink and set it back on top of the cpu. Press down on the heatsink over the cpu, fairly strong pressure.
Now test the motherboard, use just cpu, heatsink, memory, power button board and cable and external monitor, you can use your screen instead by just hooking up the cable to motherboard, leave the screen laying flat on the table. Now push the power button with one hand and the other is still applying pressure to the heatsink, no you dont need to screw it down yet. Keep reseating the cpu with varying degrees of pressure if you dont get it go the first time.
The trick will be to get it all assembled with the same results.
There seems to be a problem with the cpu seating correctly, it must come loose and the laptops exhibit the symtoms of no video. It might even be neccessary to insert a wafer thin piece of copper or something in between the cpu and heatsink if the heatsink doesnt apply enough pressure to cpu to keep it seated deep enough to run the computer.
Jun 29, 2008 | Toshiba Satellite M35X-S111 Notebook
Computer won't reboot
Hi, I can help you with this. What shows on the screen when you power it on?
Sep 10, 2007 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
174 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
