I have the samsung syncmaster 913v 19'' lcd monitor.Recently,the thing blacks out after 1 hr or so and the not optimum mode signal appears.I cannot raise the resolution above 1024x768 without blacking out again.I can usually reboot after abt 15 min to continue a session .I have updated drivers to no avail.any ideas?
It seems like a lot of people have experienced this issue after a year or two of use. There are two things people reported working...
Try adjusting the refresh rate higher or lower... 60Hz is usually stable in any resolution.
Completely unplug monitor for 5 minutes or longer. Seems like it works for some and not others.
Samsung has a 3 year warranty. If neither solution works, see if it is still under warranty.
Posted on May 20, 2008
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Mar 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung lcd television the screen goes blank after 20 mins of watching there is still sound though
right click on your desktop.go to properties.then go to the screen saver tab.click on screen saver tab.then you will see call monitor power.click on the power icon.go to the settings forr home/office desk power scheme.there you will see a setting called (turn off monitor)change that.let me know if it did work hay.
Sep 07, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung 913V LCD Monitor--No display when vga plug plugged in
1. please check by pressing num lock or caps lock key to verify that your machine is booting up, if yes then check the cable and if after changing the display cable it doesnt show up anything, it means you have a faulty unit
2. if numlock/caps lock key doesnt work, then your machine is not booting up, please check for loose ram etc.
Apr 04, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
I have a Samsung SyncMaster 913v Monitor - black streak forming
Plug your monitor into another computer, If the line persists, it is your monitor, you need a new one. If it does not, It is your Video card, you need a new one. But it is one of the other...
Feb 20, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Problema com o monitor samsung syncmaster 913N 19"
fix is easy just solder a 47 ohm resistor between pins 5 and 6 in the main transistor
Sep 06, 2008 | Samsung SyncMaster 913N 19" LCD Monitor
if there are too many black spots already then that means there are lots of dead pixels on your lcd and it cannot be repaired anymore. that will continue to add more dead pixels and eventually damage the device.
Aug 24, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Resolution Issue "Not Optimum"
Hi Guys.
I have had this problem and after a bit of searching found that it is a known problem.
Give Samsung a ring and if it's in warranty they will replace it
Jan 03, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
