Question about RIM BlackBerry 7510
Images & tunes
BB 7510 w/usb & desktop v. 4.2...(roxio doesn't see the BB)
This should be easy for a veteran BB user.
Is it possible to load images or music files thru USB?
If so, What type music files can be loaded?
Frank
  • 22 Answers
Hi
Here are the specs for that phone, I don't think it is capable of holding pictures or music.
Here is a link to the latest software I hope it helps
http://www.handango.com/aolsoftware/PlatformHome.jsp?siteId=721&osId=469&platformId=5
BlackBerry 7510 Specifications And Features Basics:
Weight: 5.85 oz/166g
Dimensions: 4.5 x 2.9 x 1.0 inches / 11.4 x 7.5 x 2.6cm (LxWxD)
Technologies:
Downloadable Applications Format: Java
PDA/Palmtop Phone: BlackBerry
Telephony Features:
Built-in Speakerphone: yes
Push-to-Talk: yes
Call waiting: yes
Caller ID: yes
Headset Jack: yes
Silent or Vibrating alerts: yes
Memory:
Phone Book Entries: variable
Display:
Color Display: yes (65,000 colors)
Display Resolution: 240x160
Customization:
Communications:
wap: yes
PC data synchronization: yes
Entertainment:
Included Games: Java
Photos And Video:
Music:
Messaging:
Predictive text input: QWERTY
SMS: yes
e-mail: pop3
Tools:
Accessibility:
Battery Performance:
• Stand-by Time:75 hours
• Talk Time:165 minutes
Battery Type: Lithium Ion
/SPH
Posted on May 19, 2008
Problem with Roxio Easy VHS to DVD Upon double clicking icon on desktop, I get the following message: "Certificate file is missing or corrupted. Please re-install it." I have a 1 year old Dell...
Copy the following into notepad and save it as user.config
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<userSettings>
<Roxio.VHS2DVD.Properties.Settings>
<setting name="EnableUEIP" serializeAs="String">
<value>False</value>
</setting>
<setting name="UEIP_GUID" serializeAs="String">
<value>1beff98f-c0f7-45fd-b1d4-83647eb9e606</value>
</setting>
<setting name="IsFirstLaunch" serializeAs="String">
<value>True</value>
</setting>
<setting name="FirstLaunchDate" serializeAs="String">
<value>30/10/2010 5:16:39 AM</value>
</setting>
<setting name="PlaybackVolume" serializeAs="String">
<value>50</value>
</setting>
</Roxio.VHS2DVD.Properties.Settings>
</userSettings>
</configuration>
Create the following directory(s) in Users-yourusername-Appdata-Local:
Sonic_Solutions\EasyVHS2DVD.exe_Url_hhfgkb1u0ycf2w3tdzo0dhp3nidmxflu\1.0.1.21
Copy the user.config file into the 1.0.1.21 folder and run VHS to DVD - worked for me!
Oct 26, 2010 | Roxio Easy VHS to DVD for PC
My blackberry storm stopped recieving and outgoing calls soon after i upgragraded my blackberry desktop manager while my phone connected to pc.even on my desktop manager it is showing disconnected. please...
The issue you describe appears to be corruption of one or more system files within the BlackBerry OS or that a file is locked in process and does not let the BB connect as it should. Below you will find 2 solutions to help resolve your issue.
If you wish to restore the BB, please continue below after verifying that you have the following:
A. Computer (Windows)
B. BlackBerry Desktop Manager software (BlackBerry.com)
C. Latest version of the BlackBerry OS for your make/model BB
D. BlackBerry USB Data Cable
A. Battery Pull
1. Remove the battery cover and battery from your BB.
2. Wait about 1 minute, then reinsert the battery.
3. Power on your BB and test it by making a phone call to test for outgoing calls.
4. If it works, proceed to step #5. If not, then skip down to solution B, step #1.
5. Ask someone to call you to test for incoming calls.
6. If it works, put the battery cover back. If not, then skip down to solution B, step #1.
B. BlackBerry OS Software Update
Note: A forced update should restore your BB to working condition, but there is the risk that you may lose your data. If that is a problem, do not proceed.
To get the OS, simply logon to your carriers website and download the latest version of the OS for your BB. Once the file is saved to your computer, you need to install the setup files just like you would any other program. When completed, proceed to step #1.
1. Open BB Desktop Manager
2. Remove the battery cover, battery and microSD card (if you have one) from your BlackBerry.
3. Connect the BB to your computer via USB cable (without the battery in place, just the phone's shell).
4. There should be a few drivers that will load automatically and the BB Desktop Manager will recognize your BB.
5. Close the BB Desktop Manager once it has been detected.
6. Go to the following path. C:\Program Files\Common Files\Research In Motion\AppLoader
7. Double-click the "AppLoader.exe" application
8. Once it loads, the application will detect your BB and proceed to update your BlackBerry's OS.
9. If you are prompted to backup your BB data, please do so. If not, then proceed to step #10.
10. Select wipe (or secure wipe) to completely remove the existing OS and data.
A fresh, updated version of the BlackBerry OS will be installed on your BB. The process takes about 35-90 mins to complete. Once done, the BB will automatically reboot and if you had an existing backup or created one before wiping/installing, you can now reopen the BB Desktop Manager and restore your backup to the BB.
Aug 14, 2010 | Cell Phones
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
I am using Roxio 7.5 to create a System Back-up. It is asking me to insert a Content CD?
In-pack is a 64-page manual, plus two CDs. One is the installation disc for VideoWave Movie Creator (V1.5.545.0); the other is the contents CD and carries video (AVI), audio (WAV) and still image (JPEG) files for use as templates within StoryBuilder. The wizard-based installation promps for the content CD to be loaded. Roxio recommends using the Full or Typical installation options, which copy the contents CD to hard disk.
Dec 29, 2009 | Roxio Easy Media Creator 7.5 for PC
Manual for Roxio Easy Media Creator 10 Suite
Please find the user manual in the following link:
http://docs.roxio.com/en/emc10/c10_userguide_online.zip
You can also find more details and FAQs in the following link.
http://www.roxio.com/enu/support/emc10/default.html
Jul 22, 2009 | Computers & Internet
This is easy,...I ma trying to install newly purchased Easy Media Creator and I do not understand what serial code is being sked for??I used my computer serial number and it was not accepted and I used a...
Hi fiddlejam, look on your box internal flaps & if not there look on the sleeve the CD came in or case. Sometimes they mark the manual for Roxio Easy Media Creator serial key. If you still can not find it than go to this link & call Roxio.
http://www.roxio.com/enu/company/contact.html
While your there register your product & creat a user ID & password. That will make updating simpler.
Good Luck & Kind Regards.
Mike
Mar 31, 2008 | Computers & Internet
RIM BlackBerry 7510 Logo
100 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
