Question about Kitchen Ranges
Oven won't come on but the light comes on. - Kitchen Ranges
  • 2 more comments
  • Anonymous May 20, 2008
    the light stays on, display says "door" but it is closed.
  • Janet Pursley May 20, 2008
    My burners are working but my oven does not turn on
  • and1066 Nov 08, 2008
    top burners heat but oven just gives me a flashing "door" when we try to use it.
  • dominium1 Feb 07, 2009
    I have Kenmore 6284527914. Stove top burners still work but oven wont come on and light wont come on
Oven will not turn on
Posted on Oct 20, 2008
"start?" light comes on and oven won't start
gas? if so then your igniter needs replacing (most likely) less possible the safety valve not operating correctly
Feb 06, 2013 | Whirlpool Accubake RF362LXTT Electric...
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Oven light won't come on
turn light switch off !! then take bulb out, then look inside socket u will see center little pin, with small flat head screwdriver gently pries out so that when new bulb goes in u r sure to make connection.
Oct 11, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Whirlpool oven won't heat after power outage
you will have to press the hand on your timer it needs to be set back on manual its on time cook you will hear it click back and your oven light will come on and heat read how to in the book that came with your oven
Nov 06, 2011 | Ovens
OVEN WILL NOT COME ON AND IT DISPLAYS F9. WHAT DO YOU DO?
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Amana AOCS3040SS Electric Single Oven
Carousel quit turning and light won't come on.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;;'
Jun 28, 2011 | Magic Chef MCO160UQ Microwave Oven
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 15, 2011 | Magic Chef 9112 Gas Double Oven
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
