Question about Creative Labs ZEN Vision:M Digital Media Player
Creative Zen just flashes
MY Creative Zen for some reason isn't working the blue led light just flashes wen you put in on charge what do you sugeest I do ?
Thanks T
  • trace1 May 20, 2008
    Mine has the same Creative Zen 30GB flashes blue LED light at power switch, wont turn on
    President:
  • 4,402 Answers
Have you tried to charge it using an ac charger?
Posted on May 22, 2008
CREATIVE ZEN MOZAIC WON'T TURN ON!!!!!
i just reset mine as mine would not turn on, i held it for a few seconds ant then turned it on and it came on! but mine is chargint at the moment, but the flashing light is red! i thought it was supposed to be green??? Can anyone help?
Sep 03, 2009 | Creative Labs Creative Technology Zen MP3...
Mp3 player will not turn on, it is fully charged
First try resetting it = To reset your zen = Put a pen head in the hole under the power button for 20 seconds.
A depleted battery may have any of the following symptoms:
The charging icon is missing
The blue power LED is not blinking
The player turns off immediately when it is disconnected from its power supply
Not showing any signs of activity (with the exception of the blue power LED)
No LCD display
The player is not detected by Windows or any programs
If the player shows the above symptoms, download the firmware below and follow the step by step instructions to install the firmware update.
http://www.creative.com/support / downloads, firmware.
May have to format if nothing eles works.
http://www.creative.com/support/ downloads
Jul 29, 2009 | Creative Labs ZEN Stone MP3 Player
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
I had a similar problem with my Zen Vision:M, whereby the computer just stopped recognizing my device. I found out it was because Windws has updated to Service Pack 3 automatically, and for some reason my player only works with SP2. It started working again when I installed SP2 again, but then I keep getting the annoying upgdate notifications from windows.
May 27, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen frozen and Reset has not worked
You probably shouldnt play with any of the buttons really but i know how to fix it. You hold down the slide power for about 5 seconds and poke the reset button with a pen tip or w.e for about another 5 seconds till it restarts itself.
Mar 28, 2009 | Creative Labs Zen Digital Media Player
Creative zen connected to my computer but i can't explore it
I recently charged my friends zen for him and the power was run down, the blue light u see is normal it is just recharging, just wait for about 20-30 minutes for it to charge a little and turn the power on, it will still charge.
Mar 17, 2009 | Creative Labs ZEN Vision:M Digital Media...
My Creative Zen won't turn on or so sizes of charging.
On the bottom is a very small hole. Put a pin in and push, it will start your creative up again.
Mar 09, 2009 | Creative Labs ZEN Vision:M Digital Media...
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Please help
download the latest firmware from creative.
http://us.creative.com/support/downloads/
Jan 08, 2008 | Creative Labs Zen Digital Media Player
Creative Labs ZEN Vision:M Digital Media Player Logo
144 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
