Question about Maytag Neptune MDG6800 Gas Dryer
  • kmaytag May 28, 2008
    My ignition switch went out on my Maytag gas dryer. This was replaced and the dryer worked great for about 3 weeks. Now the dryer is drying but with very low heat, just enough to dry after 3 to 4 cycles. What would fix this problem
    Problem Solver:
  • 14 Answers
I am curious as if you can tell if the burners are firing up. On the Neptune models there is a relay switch that has to function to tell the gas to go into the burner ports at the right time. the same relay switch also corresponds with a electric ignitor to ignite.
Second, the burners and its components must be rated for Natural gas or propane, which ever you are using.
Third, burner ports also has to be clear of debris, scaling etc.
Some have thermocouplers that go out. Some have burner blow back sensors that get worn out or dirty. Those need to be cleaned off by a technician.
It is strongly recommended that a service technician perform this service.
Back in the old days we could have used special tools to clean out each port one at a time, but now they require a bit more skill than old timers like me can do.
Make sure however your dryer is plugged into a properly grounded outlet also.
If you find that it is grounded down, and the gas components are correct, and still doesn't work, I strongly urge you to contact your local appliance repair store for technician repair to be performed.
Posted on May 20, 2008
Gas dryer heats and runs but not drying. There is very little lint in the dryer or the vent hose running outside. It takes about 3 hrs to get the moisture out.
A lint screen plugged with fabric softener deposits can block considerable air flow. Try running without the filter for a short time to see if the dryer action improves--if it does, wash the filter in hot water and detergent--allow to dry before installing. Hope this helps!
Dec 27, 2010 | Whirlpool LGR8648 Gas Dryer
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
Our Maytag Neptune gas dryer runs but no heating of the air either on sensor dry mode or timed drying we have cleaned out the lint tripa etc and it does not seem to change anything
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Nov 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer runs but does not heat. It runs continually
If your dryer never quits on its own, then your main selection switch may be bad. Even if the clothes don't dry, the timer should still only run to the end of the cycle and then stop. The problem with the lack of heat could also be caused by a bad timer switch, but that is rare. Usually it is caused by a bad igniter/heat sensor unit. Sometimes you can use a piece of sandpaper and clean the carbon off of the sensor and then it will sense heat when the pilot flame starts, then it will let the gas valve send gas to the main burner. The heat sensor it the part that is in the flame of the pilot light.
Jun 11, 2010 | Roper RGX4634KQ Gas Dryer
Dryer gets hot close wont dry cleaned vent as well
how long is the vent run,anything over 15 feet will slow drying process
Mar 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool gas dryer GGQ9858JQD runs fine not drying
Check the inlet and exit venting around the burner for lint or other obstruction.
Aug 23, 2009 | Whirlpool LGV4634JQ Gas Dryer
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Maytag Neptune MDG6800 Gas Dryer Logo
171 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
