Convergence problem I have a WS-65315 Mit. From what I have read to this point, it sufers from the convergence problem although it is intermittent. What give and is it domething that I could fix. I am an electronic tech, so all is not mystery to me. I am actually a Bio Med tech, and am willing to gamble. thanks I have a big problem, whit the convergence. alredy check and change the STK´S 394-250.but problem persist. the heat sinks get warm but not hot. and when I get into service mode can´t make any change.if it is the IC on convergence board.can somebody tell me the number please.
  • 8,617 Answers
Those are the correct ICs for that model, Did you check the resistors located right next to the ICs for being open? usually one or two of the resistors will be open. you need to unsolder one side of the resistor and lift it out of circuit to accurately check wether its open or not. let me know if you need more assistance
Posted on May 19, 2008
Mitsubishi tv ws 65315 red screen
if the reds and blues look 3d etc it is a convergence problem. see attached photos of a typical convergence problem.
Apr 28, 2012 | Mitsubishi WS-65315 65" Rear Projection...
I have a Mtsubishi ws-65315... I hit the menu and input and after 6 seconds, it blinks twice, then pauses for a second, blinks twice again, another pause, and does this 4 or 5 times... Can anyone help me...
Hello.
Most likely convergence circuit is out. Two convergence amps have to be replaced as well as some PICO fuses that already open. I would strongly recommend to let professional do this repair, without experience you can damage TV and make it unrepairable.
It should cost you around $300 to fix it at your home.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65315 65" Rear Projection...
Problem with Mitsubishi WS-65315 65 in picture simply off the screen. too big for the screen so u cant see 15% of all picture. on any input source like cable, dvd, components.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mit. WS-65315
A 21 code in mitsubishi is indicating that the set is shutting down for Xray protection. Which means voltages are rising and triggering a shutdown for safety reasons. You will need to trouble shoot the Xray circuit to locate the problem.
Jul 03, 2008 | Televison & Video
Ws-65315
The resistors will pick up the resistance from the circuits and give a false reading. You have to unsolder one leg of the resistor and pull that end out of the circuit then check it for resistance.If it doesnt register with one leg out of circuit that resiostor is bad and needs to be replaced.
May 20, 2008 | Televison & Video
Convergence problem
Some mitsubishi sets have been famous for sparse solder around the convergence ICs. Try re-soldering the huge ICs attached to the big heat sink. This will no doubt cure your problem. f not let me know
Jan 22, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Convergence issue on Mitsubishi
Check your error codes first and see what error it's given. If done right it would last. see ctechnicians.com for how to do error codes
Jan 06, 2008 | Mitsubishi WS-55807 TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
