Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Water keeps running.......
I have a frigadaire stackable washer/dryer. My problem is that the water never shuts off when it starts filling up. Even if I turn the load level to small/med/large loads. The water continues running and my washer overfload before I noticed it. Can you please tell me what part I have to get to fix this problem?
Thank you, Cheryl
    Genius:
  • 1,028 Answers
I assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
Posted on May 20, 2008
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
Jan 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a stackable Maytag. The water will not
I had a similar problem I just fixed. There is a fuse inside that keeps the water from filling if it's blown. Might try changing that first.
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
134 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
