Question about Philips CDR600 CD Recorder
Philips CDR600 hello there, wondering if you can help me with my philips cdr 600. When i switch it on it whirs a bit and then makes some clicking sounds before displaying the INSERT DISC message, when there is certainly a disc within. Any ideas? All the best, Daniel danielfell@hotmail.co.uk
  • jazzdude Jun 26, 2008
    I have a similar problem. I have a Philips CDR600 and it was working fine one day but the next it could not detect a disk when I put one in. I thought it was just worn out so I found a CDR602 on eBay. It looks identical to the 600. After a couple of weeks the same thing happened. I have tried using a CD lense cleaner disk but the device will not even spin it. The only thing I can think of is they both seemed to have gone faulty after my wife used the shower and didn't open the window hence the house was very steamed up and humid. I haven't had time to strip the units down to clean them manually yet.
Your cd burner has burned out it's burning laser.You must get a replacement assembly about $150 for the part and also someone to install it for you.
Posted on Jul 19, 2008
Need Manual for Koss CDR600
Try owners-manuals.com and if that is not there then do a search on the internet as well as the manufacturer website.
Dec 08, 2012 | Marantz CDR632 CD Recorder CDR-RW with...
Cannot unfinalize the CD RW disc.... I press ENTER to unfinalize but when the countdown arrives at 53sec it switches off and the disc remains finalized - please help !
clean the cdr with a cd cleaner if that doest work u mite need a new cdr. hard 2 find cdrs that work 4 philips am looking i got a cdr 788
Mar 15, 2011 | Philips CDR796 2-Disc CD Recorder
Philips cdr 950 keeps saying update tem senconds into recording from lp very frustrating
you may have to do a firmware update see if the website has a support page that has firmware downloads and how to burn them to a disk
Jan 03, 2011 | Philips CDR600 CD Recorder
Philips 765 CDR - twin deck
Remove the 765's casing. If you don't have a star shapped screwdriver use a flat head which sits tight in the screwheads diagonals. Once removed, observe the 765's driver chip which sits behind the recording deck mechanism of the left hand deck. With the power cord disconected carefully remove this chip by gently working a flathead driver between the chip and it's base (the chip is not soldered to it's base but take care not to bend the pins) Once removed, power up the unit for a few seconds making sure that you do not touch the live internal workings. Remove the power cord again and switch the power button on for a few seconds(with no power chord attached) to allow the units capacitors to discharge fully . Gently replace the driver chip. Replace the cover and switch the unit on again. The unit should reboot and the gremlins should be gone.
Jun 03, 2009 | Philips CDR600 CD Recorder
My CD Recorder is not reading my blank discs. What can be the pro
hi not sure if this helps but some disc ,s ive used on my 500s won,t work either so i changed the type of disc and it seems to do the trick i think some disc,s just aren,t good enough ie cheap ones .
Jan 13, 2009 | Philips CDR600 CD Recorder
Wrond Disc
The disc you need to use to record is "PHILIPS CDR MUSIC". That is what it should day on the top of the disc. On the left side of the disc, it should say "DIGITAL AUDIO RECORDABLE". I spent a lot of money buying the wrong discs before finally finding the correct one. So I know your frustration!
Apr 05, 2008 | Philips CDR600 CD Recorder
PHILIPS CDR 600
I think you hold in the 'display' button when the unit's off in standby to remove the dealer lock. It's designed to stop shoppers nicking cd's when the units on display in a shop. If this doesn't work post back and I'll try it on my cdr600.
Jan 14, 2008 | Philips CDR600 CD Recorder
Not reading blank cdr audio disks to record onto..
Will it read audio cd's? Sounds like you need a new laser unless you have access to a philips COMPair system to diagnose / realign it.
Dec 12, 2007 | Philips CDR600 CD Recorder
Philips cdr600
Needs a new laser or realigning service using philip's COMPair diagnostic system.
Oct 13, 2007 | Philips CDR600 CD Recorder
Open Questions:
Philips CDR600 CD Recorder Logo
297 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
