Question about SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player will not Recharge
Tried unlock... no help
Tried usb on another computer... no help
Seems my autodetect isnt autodetecting my MP3
Seems after i downloaded XP service pack 3 no more MP3 recharge.
Is the firmware in the MP3 out or ?
help please
thanks, Eddie
  • Anonymous Aug 15, 2008
    my sansa 1 gb mp3 is nto recharge and not shown in computer pla slove it
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
MP3 player won't recharge
It could be possible that the connection on the mp3 player is damaged, which would explain the connect/deconnect sounds and the recharge problems.
Jun 21, 2009 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250..thnkx.!!
I think maybe it isnt connected to the computer corectly because it should go to the connected screen. try hooking it into the main USB ports.
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
E250
SETTING USB MODE
1. Select Settings menu in Main Menu.
2. Select USB
3. You can select AutoDetect or MSC mode.
Note: AutoDetect will default to MTP mode. The MTP mode supports Windows Media Player 10 only.
You must use the MTP mode to synchronize music files using Windows Media Player 10 for the optimal
system performance.
Mar 27, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 won't charge
I had the same problem - the player needs to be unlocked (the little switch on top) to be able to charge - pretty stupid if you ask me but what can you do
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
My computer is not reconizing my sansae250, i have the vista system
i just moved back with my family and do not have my computer though my sister has an ipod USB cord but my sansa MP3 player 6.0GB wont recharge, how can i get my sister's computer to recognize my MP3 player?
Dec 17, 2007 | SanDisk Sansa e250 MP3 Player
Sansa mp3 player
If the player is in MTP/Autodetect you can just unplug the player from the computer. You can check this by going to the My Computer window and see if the player is listed and if it has a drive letter before it, if it dont have a drive letter then it means the player is in MTP/Autodetect you can just unplug the player from the computer.
Aug 13, 2007 | SanDisk Sansa e250 MP3 Player
Computer won't read mp3 player
Try checking for the mode the player is in, SETTINGS>USB MODE> choose MTP/AUTODETECT. It may be that the setting is in MSC that is why it is not being detected by your computer. If all else fails try updating your windows media player software.
Jul 23, 2007 | SanDisk Sansa e250 MP3 Player
I can't put songs on my Sansa Sandisk e250....
Hey to get music onto the Sansa e250R you have to plug the Sansa into the computer. Next go to mycomputer. Then onen ethier sansa or Removable Disk(F:). Then take the songs you want and drag them on to the white space under photos and vidos and all that other files. DO NOT PUT IT IN A FILE.
Jan 27, 2007 | SanDisk Sansa e250 MP3 Player
HOW DO YOU UPLOAD VIDEOS AND PHOTOS
Try plugging your player into all of the USB slots on your computer. If that doesn't work, switch your USB mode in settings and try again.
Oct 01, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
