Question about Canon PIXMA MP160 All-In-One InkJet Printer
MP160 Error E3
Hi, my printer has been having trouble feeding paper and although it doesn't pull the paper through it is displaying error 3- help! I've tried everything!
  • Anonymous May 25, 2008
    I have the same problem and can't figure it out. I just adjusts itself before printing and then never pulls paper through and i get he error message.
  • Anonymous May 26, 2008
    mine too. Say's out of paper, but it isn't. I've cleaned all parts according to directions, but still won't feed properly. Maybe a bad sensor?
I work in a shop repairing these printers and have had a large number with the same fault - displaying E-3 with no jam in the paper path. This is caused by a broken part in the paper feed mechanism that pevents the printer from taking the paper. The part located right at the bottom of the printer looks like two white gears connected together with a central spring. At present I am trying to find a supplier of the spare parts - will check back.
Posted on May 28, 2008
Printer will not feed paper and displays error code E3... have tried cleaning the feed mechanism as per the owners manual but problem persists
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-20
Aug 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Tip
Code error PIXMA MP160 All-In-One InkJet Printer
this error list PIXMA MP160 /150 All-In-One InkJet Printer
CANNON PrintersMP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported inkcartridge is installed ,
or the ink cartridges are notinstalled properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera /video camera does not support Camera
DirectPrinting
E14 The Ink cartridges whosedestination are wrong
E15 Ink cartridge is notinstalled E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature riseerror
E27 Waste ink absorberfull or platen waste ink absorber full
E28 Ink cartridge temperaturerise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
on Mar 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
MP 160 flashing error E then 3. doesn;t respond to anything I try to reset it
hi,
mbhd13
Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E3 error on display.
Try cleaning the paper feed rolles with nail polish remover. If problem presist replace the feed rollers.
Feb 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E3 code error mssg on printer MP160
As you will probably know E 3 on Pixma is paper jam.
Double check that there is no paper inside, and turn printer upside down shaking it a bit to check if there is any small foreign object (screws, pins, coins etc.) stuck inside.
When there is no jam in the paper path, this problem is typically caused by a broken part in the paper feed mechanism, in the page unit.
The paper feeding mechanism has two white plastic gears connected together with a central spring, near to the waste ink tank, at the bottom of the printer.
This are quite delicate, they often get stuck or boken, or you lose the spring, and the printer stays stuck with E3 error.
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E5 and 2,114,0 errors on Canon MP160
Empty cartridges may cause this error. Here is the error code list for your printer
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
CANON PIXMA MP160 E3 error
May 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Pixma mp160 error message
Ok, my machine was also showing E3, and would NOT go away. My solution: turn the machine off, feed a piece of thick cardstock into the paper feed.Turn the machine on, let the machine take the paper almost all the way in, then pull it back all the way out against the feed. My E3 disappeared and has not yet returned!! Hope this helps David
Nov 26, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
354 people viewed this question
old marine
old marine
Corne Viljoen
