Question about iRiver H10 MP3 Player
System initializing the system initializing wont go away. i replaced my battery and i thought that would fix it, but it hasnt. what should i do?
What the mp3 doctor is saying does not work so please stop saying that
Posted on Oct 14, 2008
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 27, 2008
Battery wont charge and replaced alternator and since then the battery hasnt held a good charge
Did u replace the battery too? Most often than not if u replace alternator u must do the same with battery.
What year is automobile? And how do u know battery is not holding charge? U using a device to test it or car just won't start?
Nov 18, 2013 | 1995 Nissan Pathfinder
Engine wont start after charging, will start with a jump. The pto will not engage
Sounds to me like you need to scrape the **** off of the battery cable ends and the battery posts,or you just have a battery that has sulfated and will not take a charge.Repairing the connections or installing a new battery should fix the starting problem and because the pto is engaged with electricity it should fix that too.
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Car wont start changed the battery but doesnt
have your alternator checked. I have recently had the same issue in a different brand of car. Initially thought it was the battery because that the system light that displayed for the issue. However when taken in to the shop found out there was nothing wrong with the battery, something was failing in the alternator. This problem is most present in extreme cold and hot conditions.
Dec 12, 2009 | 2001 Ford F350 Super Duty SuperCab
My car won't start it simply keeps clicking when the ignition is turned on, turned on the lights , radio and interior light all was working what is happening
Sounds like you need to replace the battery,the battery can have enough power to run lights, stereo,and other accesories but it takes alot of amperage to power the starter motor, so if that is the case you will hear the starter solenoid clicking but no action from the starter. Good luck. !
Nov 30, 2009 | 2000 Toyota MR2 Spyder
Engine seems to run good then goes downhill
Have a look at the fuel pump it looses pressure when hot which means it is due to be replaced.
rate this please
May 24, 2009 | 1991 Subaru Legacy
Power going away..
Have you tried stretching the contacts upward to hold the battery more securely?
Jul 23, 2008 | Nikon Coolpix L11 Digital Camera
My computer keeps turning off
I am encountered that kind of problem before i am also trying to replaced some of my comuter parts but the problem still there. I am only solved the problem when i installed pctools spyware doctor. pctools removed a lot of spyware virus in my system and i installed the registry mechanic to fixed the registry. After i reboot my computer the problem is gone. the spyware virus sometimes is cause of the compuer to shutting down automatically without any warning messages.
Apr 15, 2008 | Abit KN9-SLI Motherboard
IRiver H10 Problem...
Hard drive finished.
The iriver usses the Microdrive, which is a piece of sh...
I wonder can replace the Microwith the Compact flash.
Ipod mini & Creative can use Compact flash
Apr 09, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
91 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
