Question about Vacuums
Vaccum overheating I have a hoover u5458-900 wind tunnel and the auto shot off has kicked in for overheat protection. i've cleaned the entire thing and let it sit like i was supposed to but it still won't fully turn on and stay on. it will turn on for a few minutes and then shut off and just cycle like that for a few times. is there anything i can do to fix this or should i just clean it more (if possible)?
  • 1,673 Answers
Either the motor protector is bad, or you have a clog in the hose or the dirt inlet by the brush roll. Are the filters clean? It is also possible that there is a problem with the motor.
Posted on May 20, 2008
Why is it my vacuum cleaner keeps shuting off after ten minutes. i have a Hoover wind tunnel uh70086
Sounds like it has an overheat problem and is shutting down to protect itself. Make sure the exhaust filter is clean and that there are no blockages. Hoover UH70086 WindTunnel Cyclonic Pet Rewind Plus Upright Vacuum Parts...
Sep 17, 2015 | Hoover Vacuums
Hoover wind tunnel the red light dirt finder stays on
There's a microphone inside the tube the dirt runs up. It listens for dirt coming up the tube. They just go bad and there's no making it better. You can either replace that entire assembly or ignore it. Fairly easy to replace. I'll include the part so you know what you're looking at.
Good luck! The Vac Dr.
Jan 13, 2013 | Hoover Company Wind Tunnel U53019 Upright...
My Hoover wind tunnel keeps overheating and the red I dictator is on. I have cleaned all filters and checked for clogs....could the motor have dust in it? How do I check?
Okay. I read these posts and decided to take the advice of checking the hose.
I had cleaned all filters, checked all hose (as-is) and did belt checks, etc.
The indicator was always showing red and it would shut down after about 5 minutes.
It ended up being a clog that I discovered after taking the hose completely off and seeing a clump right where the hose detaches. I began swinging the hose round and round and sure enough, more cat hair clumpls shot out. Big clumps.
So, you literally need to check every inch of hose to find the culprit.
After that, my indicator stayed green and it works like a charm.
Best wishes, Mike D
Dec 03, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Hi My Hoover wind tunnel cyclonic stopped working when i was using it. I tried different plug even then it doesnt work . What to do??
If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
Dave in Texas
Aug 31, 2010 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Uses a "type Y" Hoover bag. Hope this helps, if so, leave feedback when asked. Thank you, Rene(the Vacuum Doctor)
Nov 09, 2009 | Hoover Vacuums
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Hoover Wind Tunnel Problem
motor burnout. replace the motor or get a new vacuum
Dec 15, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
193 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
