Question about Video Game Consoles & Games
On PSP changed laser and screen, still won't read umd.When in system settings and trying to change nickname won't let me type, seems as if a button is being continuously pressed.
    Scholar:
  • 102 Answers
Well first of all did you make sure you got the right model umd. u cant just throw any model on there and expect it to work.
it could be also not be the laser. the laser glider might not be moving. or the spindle might not be working right.
get a new laser assemably.
has for the button issue. open up the psp and clean it really good with rubbing aclohol. if that dont work they its prolly a issue with your motherboard. u can either pay 90.00 for a new board or get a new psp.
Posted on May 20, 2008
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Ello. My PSP won't read UMDs. The loading
Most likely the laser is weak. It has been awhile since I have changed a laser in a psp. But first off you should clean the laser with a q-tip and isopropyl alcohol and dry it with the other end of the q-tip. It doesn't take much for them to not be able to read a disc. If it still doesn't work you will need to replace the laser if you aren't that great at working on electronics or very small things you need to find someone to do it for you.
Nov 01, 2017 | Sony PlayStation Portable (PSP) Slim...
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp not reading umds
Your psp umd laser might be broke if you go to ebay.com and type in psp repair you will see people will fix them.
Nov 10, 2008 | Sony PlayStation Portable (PSP) Console
Psp problem
Once you get the message or during game menu, press select, scroll to UMD ISO MODE and change it to Sony NP9660. Exit. Enjoy.
Aug 14, 2008 | Formula 1 2004 for PSP
PSP hanged when switch on. The usual screen appears but without the menu icons except for a small circle at the bottom right hand corner which keeps spiinning. Icons will only appear when I open the UMD...
conect your psp to you pc/lap top and find a default setting for your psps this are just like other peoples psp saved dater try that look on game sites and console cheats sites
May 09, 2008 | Sony PlayStation Portable (PSP) Console
HELP PSP WONT READ UMDS!!!!
hi i just fixed my sons it wasnt reading umd's every thing else worked so have a look were the threaded rod runs threw the laser, in the centre at the back of the laser there is a little tab with a stamped groove in it make sure the laser is up against the disk spinner when turned off push the tab against the threaded rod hopefully it has seated (you ned a good light plus i used long metal twesers to push it down, easier to see on 2000 model than the fat one but you can manage good luck)
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
41 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
