Question about Brother Office Equipment & Supplies
Put in new cartridges and now printer says unable to print routine maintenance no paper jam or forien objects
  • littlemidget Jun 30, 2008
    i moved across town. Printer was working, but when i
    set it up at new house said needed black ink (even know 3/4's full) so i filled
    all the inks, now i get the unable to print see routine maintenance of
    manual?? Can't find anything in the manual about it??
Try resetting the factory presets. While in maintenance mode, press either 01 or 91. Wait for the machine to beep at you again, then press 99 to get out of maintenance mode. You may also have to let the unit cool off (power off for about 15 min) and try the reset code and the 99 to get out of maintenance code.
Posted on Jun 25, 2008
Init Unable 48, See troubleshooting and routine maintenance chapter in User's guide
What is the condition of your print cartridges? They could have dried out during the 2 month period that you didn't use the printer. Try, cleaning the contacts of the cartridges and the printer. If you have new cartridges to try....even better.
Jan 15, 2008 | Brother MFC 240C All-In-One InkJet Printer
Unable to init.
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Dec 20, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a color MFC 5 in 1 printer
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it. Sounds like something is jamming.
May 16, 2009 | Brother MFC-5440CN All-In-One InkJet...
TROUBLE SHOOTING
I am having a problem as well. I can't use the Fax either. Very difficult to see th jammed paper. Followed all instructions, but unable to clear the jam.
Feb 18, 2009 | Brother Multi-Function Center MFC-3360c...
Unable to Print
plz try by reinstalling the printer
Nov 27, 2008 | Brother MFC-620CN multifunction Color...
Mfc-5460cn
Now the printer bar is all black lines neatly lined up and I can't even shut it off!!!!!!!!!!!!!!!!!!!!!
Oct 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
DCP 115C does not print
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely
the manual states for this problem
"The machine has a mechanical problem.
OR
A foreign obstacle such as a clip or ripped
paper is in the machine."
Aug 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Not printing
my printer doesnt work, what do i need to do so that i can use my printer again,pls kindly give me the information, it always said that go to the maintenance and routine maintenance chapter. i have no any idea on that device, pls!!! thanks!!!
Jul 03, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
65 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
