Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Mod #GD5RHAXNQOO Inside light will not work inside, I replaced with new bulb.
  • kay2647 Jul 21, 2008
    replaced bulb and switch, someone said it might be a chip?
  • 868 Answers
Possible that the door switch is the reason.Check for powerat the door switch
Posted on May 21, 2008
Fix a burned out light bulb on dryer?
there should be a light bulb housing in the inside back of the dryer. most just need a screw driver to open in, just remember to unplug the dryer before do any kind of electrical work...that includes changing a light bulb. unscrew the housing, make sure not to lose any of the screws. with the correct light bulb, just replace the burnt out one with a new working one.
Dec 25, 2014 | Refrigerators
I have a Harbor Breeze mod E-BE44. Fan works but lights stay on for 20 seconds and then go off. I hear a click inside when that happens.
is there a remote control unit with it that may be turning off the light waiting for the signal
Mar 06, 2012 | Dryers
My tail lights are not working on my 2000 jetta the front lights work the break lights work and the blinkers work all inside lights work just fine
you need new bulbs in tail lights one bulb in each side has two elements one works brake other works running lights the elements in the bulb for tail lites are bad . so just replace bulbs. hope this helps.
Sep 13, 2011 | 2002 Volkswagen Jetta TDI
Inside light went out...replacing bulb did not work, any help or advise? thanks! Mike
Many times when the inside light fails to operate...it could be:
(1) A bad bulb ...replace with a known good one.
(2) Bad connection of the light bulb in its socket.
(Remove the bulb and spray the socket with WD-40 Spray Lubricant) then...
(3) Replace the bulb with a known good bulb..use a dry rag to securely tighten the bulb in its socket.
(4) The "Door Switch" could be bad. Replace bad "Door Switch" with new one.
Hopes this helps....Good Luck! ...... HandyHenry
Mar 24, 2011 | Whirlpool Refrigerators
MY REFRIGIRATOR INSIDE BULB/LIGHT IS NOT WORKING HOW TO REPLACE IT
Go to the hardware store and ask for an applianece light bulb. They are normally 40 watts. Turn your refrigerator off and take out the bulb by twisting it out. Replace with new bulb by twisting it in.
Aug 17, 2010 | Refrigerators
2002 blinker light replaced works but sometimes
try replacing the tail lamp socket. it could be shorting out
Mar 15, 2010 | 2000 Chevrolet Cavalier
How and where can I replace the inside light bulb of a Magic Chief micro wave oven. Mod. #MCD1311ST Magic Chef Microwave Oven
The bulb is usually under an access panel on the side or back that is held on with a screw or two.
Feb 10, 2010 | Coffee Makers & Espresso Machines
Light inside does not work, even after putting in a new bulb. Could it be a bad door switch. If so, can I replace it. How do I replace it?
It probably is a bad switch, in most firdge the switch is installe in a pop-lock construction. maybe the spring inside the switch is busted. Also please check the bulb you bought. it should be rated for refrigerators or else it wont work.
May 08, 2009 | Refrigerators
Parking light - how to replace? 240 DL
these are easy. pull the cover off of the light assembly inside the trunk by turning the screws at the bottom. find the bulb that you want to replace once inside and gently turn the bulb holder until it comes free. the bulb inside will itself twist out. put the new one in, reverse the process and drive on.
Sep 03, 2008 | 1984 Volvo 240 Series
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
