Back to:
Tags:
Kitchen Ranges
Generic problem for all Kitchen Ranges
I set my stove to
posted by rm_blackmore on May 19, 2008
I set my stove to self clean for the oven and received 2 errors....fe51 and fe20...and not able to locate the manual to check troubleshooting...please help..Rhonda
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 20, 2008
Thanks for Trying (70)
fixum1
Rank:Guru Guru
Rating: 88%, 487 votes
need model number
Comment by fixum1, posted on May 20, 2008
need model number
Rating Locked! (?) rm_blackmore has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I set my stove to:
I don't want to Accept this solution
Solution #2
posted on May 29, 2008
Not Rated (0)
reg501
Rank:Guru Guru
Rating: 90%, 262 votes
F51 indicates a door latch issue, F20 indicates temperature issue. Self clean on many stoves can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
I can't seem to fit the main oven door seal , is there a...
GE Profile JGSP44 Dual Fuel (Electric and...
My GE gas cooktop has a problem with the knob/spark...
Kitchen Ranges
zanussi double oven cooker gone dead 8yr old
Kenmore 94223 Electric Kitchen Range
By accident I press the lock button function on the...
Kitchen Ranges
I have just moved and have inherited a Bosch gas hob....
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
