Tv tuners I have 2 tv's that are broken. the one I think has a motherboard problem and the other lost its tuner can I swap tuners and get one working again. both are the same size tv but different brands>
  • pop5cents May 23, 2008
    thanks for the info I willcheck thefrequencies and give it a try
    Genius:
  • 1,224 Answers
Ive never had a problem swapping tuners just gotta make sure frequencies are the same for the tuners is the only thing this will be inscribed on the side of tuner module
Posted on May 20, 2008
Can't get pnp to work
I presume you mean PIP which is picture in picture---the only button which will control it is on the original remote--PIP, SWAP etc.
The set uses two tuners inside for this--one is main and other is PIP--you may have a bad tuner.
If PIP button brings up a screen--hit the swap to see what happens-if one is nothing or snow and other has a picture--got a bad tuner--it can be either (some are combined into a single tuner).
Jun 02, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a 2 tuner tv. When Cablevision installed my digital cable box, I lost the 2 tuner capability. Is there a special way it needs to be hooked up to get back the 2 tuner capability?
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See tvfool.com for antenna types and direction or antennaweb.org for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
(please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
Nov 05, 2010 | Proview PA-32JK1A 32 in. LCD Television
Line in problem of tv tuner with DG31PR board
u must connect speaker on tv tuner card;s jack. and go in control panel click on sound and audio device than select audio and change sound playback default device.thanx enjoy good luck plz vote on my comments
Jun 16, 2009 | Intel DG31PR Motherboard
GIGA POCKET TV TUNER NOT WORKING
PROBLEM SOLVED. APPARENTLY THE GIGA POCKET PROGRAM IS AFFECTED BY THE SONIC STAGE MUSIC PROGRAM OF SONY. I RE-FORMATTED AND DID NOT INSTALL THE VAIO MEDIA AND SONIC STAGE SOFTWARE ...
THE TV TUNER NOW WORKS FINE ....
I JUST USE WINDOWS MEDIA PLAYER AND WINAMP FOR THE MUSIC ....
NO REMOTE CONTROLS ... BUT THE TV TUNER WORKED .... ONCE MORE ....
May 19, 2009 | Sony Computers & Internet
Philips SAA7130 TV Tuner/FM Radio/Video PCI remote stopped working
PLEASE THE SEND THE TV TUNER CARD DRIVERS I AM LOST THE TV TUNER CD
May 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Turns on but nothing else works
Your probably correct, however, the tuner also has serial/data lines going to it so the tuner can cause that problem but highly unlikely.
Feb 03, 2009 | Polaroid FLM-2632 Television
Driver problems with OEM 7130AA WDM Video Capture device (Phillips chipset)
Hi.
Use this to update your drivers
http://rapidshare.com/files/149632922/Driver_Scanner.rar
Hope this helps.
Regards
Faraz
Oct 14, 2008 | Philips TV Tuner Video Capture PCI Card -...
TV Tuner Card is not working on DG31PR Motherboard
You should always install mainboard drivers first.
Remove tuner card, install all other drivers, then add in Tuner card.
Aug 05, 2008 | Intel DG31PR Motherboard
RCA D61W130 tv
this unit has two tuner modules. one is the main tuner and the other is the slave or the pip tuner. it would apear from your description that the main tuner has failed. it is possible that this can be replaced.
Jan 28, 2008 | RCA D61W130 61" Rear Projection Television
Lost channels 2 through 52
I think the low band (Channel 2-6)in your tuner is not working. This could be in the tuner itself or in the band switching circuits. Possibly she deleted the low channels or locked them out. Stargazer
Jun 14, 2007 | RCA F32632SB 32" TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
