Question about Nintendo Wii Console
Wii remote I have the issue where the wii remote does not show any arrows but it shows some lights and does not turn the system on.. I haven't purchased new batteries but I have switched to batteries that work for other remotes in the house
    Problem Solver:
  • 7 Answers
You have to get the wii remotes circuit checked by a qualified electrician, as it shoudl not do this, and is quite possibly faulty if it does do that.
Posted on May 20, 2008
Programed the first wii remote but the arrow (on the game on the television) keeps dissapearing. what do i do now? does this mean the remote is not hooked up correctly?'
Press the home button on the Wii Remote and point at the screen. If the hand does not show up, there might be a problem with your Sensor Bar. Make sure it is plugged in correctly, and the Wii Remote has a clear path to it.
If the hand does show up after pressing the home button, it might be that the game is not meant to show a cursor when you point at the screen.
Aug 21, 2011 | Nintendo Wii Console
My Wii is not working. It will come on but the remote will not sync with the console (the hand does not appear on the scree). We purchased a new remote but it still is not working. We pushed the red...
You will have to update the wii to play newer games. Your controller problem if it does show a led light on the remote then its synced. If its just not showing you a hand on the screen then its probably your sensor bar. If your controller will not sync and all four leds flash then I would push the button on the console and push the button the remote then just try hitting the a or b buttons. I've also had to slap the remote after hitting the sync buttons to get it to sync. The update thing is normal though.
Jan 10, 2011 | Nintendo Wii Console
I have a wii remote charger and have just purchased some rechargeable batteries but they don't appear to be charging, everything is set up correctly but remote only showing 1 light lit and then going dead
Make sure your charger is plugged in your Wii AND turned on. If you do this, the remotes should charge.
If the remotes still don't charge, there's a problem.
May 03, 2010 | Nintendo Wii Remote Controller
The lights on the wii remote flash but wont turn on and show the arrow on the screne
Sound like it needs to be properly connected to the wii. Power it on and look under the SD card panel. There is a button there (red I think) that you need to press. At the same time you doing that, press the red button on the Wiimote (located next to the batteries). Try this a few times, and then press A on your Wii remote. That should properly sync it with your wii.
Mar 20, 2010 | Nintendo Wii Remote Controller
Made a loud noise and then wouldn't turn on t.v.
you need to reset the configuration and it also happens when the systems been on for a long time unplug the main power supply for 30 mins and try again. hope this helps and also try and clean the disk and let them dry.
Dec 31, 2009 | Nintendo Wii Console
Wii Remote ligths do not turn on.
The same problem happened to me when i accedently spilt some water on my wii remote. Try to see if anyone in your family may have done that or if you did.
Jun 17, 2009 | Nintendo Wii Remote Controller
Wii remote not working
Check the sensor position, whether it's on, and how far away you are from it Wii remote sensors a can be really annoying
May 20, 2009 | Nintendo Wii Console
Wii Remotes can turn on but no arrows.
I had the same problem. When I looked at my system, I noticed the sensor was turned sideways with my tv remote in front of it. When I turned my sensor around correctly, and moved my tv remote away from it, the arrows suddenly appeared! Make sure nothing is blocking your sensor!
Jan 07, 2009 | Nintendo Wii Console
Discs wont register on wii system, remote wont work either
You need to sync the remote with the console.
Remove the battery cover from the remote and press the red
button until the blue lights start to blink. At the same time,
press the the red button to the front of the console.  You
can access this button by removing a small cover on the front
of the console. This will reset the machine and you should
start to see th cursor in the tv screen. Repeat this if necessary
and you should be on your way. Good luck
Sep 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
65 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
