Question about Zenith A32B41W 32" TV
Burned capacitor? I have a capacitor? that has burned, I cut it loose and TV works fine except for a sm vertical line on the left. It is a CK3231 or ck3232 what is it and where can I get one
  • 4,234 Answers
If it is CX3231 it is a ceramic disc capacitor 1000 picofarad, 2000V.
Dan
Posted on May 20, 2008
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
My TV has a white vertical line about 8 in wide on the right side of the screen followed by a few blurry vertical line going toward the center of the screen the left side is fine
More burned capacitors.. You have a center and sometimes a right and left circuit board. If you have to visit the board more than once in just a few months you will have to call the LG tech. You need to replace one of the boards. I tried the self repair route and nearly ruined the TV. Take it from me ...call the tech.
Jul 06, 2015 | LG 60PV250 60 in. Plasma HDTV
Evenly spaced vertical lines
Hello
Check the smoothing capacitor to video output supply voltage, usually derived from any one winding of the LOT. It will come around 10uF350VDC to 47uF 350VDC range. If this capacitor is faulty, or gone less in capacitance with time, this type of fault will occur. Check the green volour output transistor on the video output card, can be located attached to the neck of the picture tube; for any loose soldering or leakage. OK.
Oct 19, 2011 | JVC AV-32P903 32" TV
My picture tube displays all black except one thin horizontal line in the middle. There are no horizontal or vertical adjusts that I can fine. Is the picture tube burned out with just this one line?
Hello
A thin horizontal line across the screen denote that the vertical swep or output has damaged, or there are some loose solder points to vertical output section. Loose solder problems are very common to the vertical output sections of most of the picture tube based TVs. Just open your Tv, and pull out the main baord out of it, which has the vertical output section circuit. You must have some knoldge in electronics to proceed. Locate the vertical output section. usually, this section will be composed of an IC, which will be screwed on to a metal heatslink, to radiate heat out of it when it works. Check whether there is any loose solder terminals at this section, especially look for it at the solder terminals of IC and other components around it.
It is very difficult to detect the loose solder points, as some of them may be so microscopic to detect. Just do, what we do at service table, with this type of fault comes to us. Just resolder most of the suspected solder terminals by applying a little more solder without making any sokder bridge short between adjecent solder terminals.
If this does not help you, check the input voltage to the vertical IC. If found OK, replace the vertical output IC. If there is no voltage to this IC, check the track that brings voltage to that IC. Usually, this voltage will come from one amoung the terminals of LOT [Line Output Transformer]. Check the track, rectifier diode, limiting resistor etc. This is really a skilled work, and you should have all tools for an electronic work, and a skill to detect the faulty component. OK
Sep 16, 2011 | Durabrand DWT1905 TV
Tv runs fine for 30-45 minutes then goes black except for bright horizontal line thru center of screen, volume stays on
This is a vertical problem. It may have a bad solder joint or it has a vertical IC or surrounding compoenents heating up and going bad, Try not to have the horizonal line on for to long, it can burn the screen if left on very long. If you have some electronic experience you could get some freeze spray and wait for the set to mess up and spray the freeze around the vertical section and locate the part that is heating up. Be careful because there is HIGH VOLTAGE is this area. Hope this is helpful.
Dec 03, 2009 | Televison & Video
Black line
I just had this problem with my Samsung 50' DLP HLR5067WX/XAA. Fortunatly it was still under warranty with Best Buy, so they fixed it for me. They had to order a brand new light engine. (or where the mirrors are, if i'm not using the right terminalogy) He said the problem is with one of the mirrors that has slipped (or slipping because overtime the black line will get thicker and thicker). I hope i'm saying it right, but it was with a tiny mirror that was slipping. Hope it's under warranty. I've also had 1x component plug burn out on me, my HDMI port went to ****, and he's gotta come back out because when he made the repair, the picture was reflecting too high up and to the left. (MLB 2k7 for xbox 360 - scores on top of screen are about 1/4th cut off). He said is next trip back to my house would result in me getting a new TV, so can't wait for his arrival! good luck with your tv
Aug 10, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Sharp 27G-S60 no vertical picture
your problem is due to vertical section failure.
 as you say it was intermittent for a while, but now is permanent
please check the followings as given
  • remember you should keep brightness as low as possible to avoid crt burn.
  • there might be loose contact in print or connector loose for deflection coil.
  • check supply to vertical output section
  • check components in vertical output section like electrolytic capacitors & low value resistirs.
  • check verical outout ic .
  • hope this will help
  • good luck.
Oct 13, 2007 | Sharp 27G-S60 TV
Re: ask assistance
caution reduce brightness to protect crt burn. vertical line with sound ok is due to 1 deflection coil connector loose or wire going to horz.coil disconnected. 2 capacitor going to h/winding loose or defective. 3 print break from eht to h/coil.
Sep 29, 2007 | Televison & Video
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Picture is cut off on top and bottom
Thats is not going to fix your problem. You have a bad vertical output IC and or a bad capacitor in the vertical drive or output circuit. Good Luck
Mar 31, 2007 | Zenith C27A24T 27" TV
Televison & Video Logo
183 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
