Question about Brother MFC 420CN All-In-One InkJet Printer
Copier wont int.
Paper jam pulled out now makes cliking sound and
screen says unable to int see manuel
but i dont have one
  • 105 Answers
Unable to Int. 5a
This is a paper jam/sensor error. look for any foreign object in the paper path or printhead area. even a small piece of paper. Try blowing (not with a compressor blower!) all through the internal areas of the printer to dislodge dirt, dust or other contamination from sensors.
Mar 25, 2015 | Brother MFC-685cw InkJet Printer
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
My copier wont feed paper. no paper jam. paper holder is not locked down. It is in the right position. I can hear the paper feeder trying to engage but nothing happens, then a "p" appears on the screen....
It sounds like you will need a tech to come out and replace your feed and seperation tires. If you pull your tray out and remove your toner 1st! Look under and you may be able to see the wear for yourself. I would look close to make sure before paying a tech service call.
Jun 09, 2010 | Sharp AL 1631 Copier
I had the Bro 8840D repaired following a paper jam. I am unable to get it to pull paper through. Says paper jam, but no jam exists. The tech repair shop said a switch had been flipped when the first jam...
okay, try this...clear the paper jam message and try to make a copy using the manual bypass (MP tray) located on front of machine. if copy comes through okay, then chances are you have a problem in main cassette area. pull cassette out, and make sure the rear stop inside cassette is not pushed too tightly against rear of paper stack. should leave about 1/8" gap. if thats okay, then sounds like you may need your paper pickup roller replaced. sounds like your repair shop just fixed the error, not the cause of the error.
May 24, 2010 | Brother MFC-8840D All-In-One Laser Printer
Phaser 7300 jamming manual feed
Can you print fine with no jams from the lower tray?
make sure you have clean new paper and start out with the 11"x8.5' letter paper. If you have that then follow the instructions below.
  1. Make sure there is no peaces of paper jammed in the path.
  2. clean the rollers with regular rubbing alcohol sometimes the rollers get way dirty to pick up the paper.
  3. If none of these tricks helped you then you have to change the the manuel feeder. part # 116-1561-00 good luck.
Dec 07, 2009 | Xerox Phaser 7300DN Laser Printer
Unable to print
If the paper sensor tab is broken you will need a shop to repair. Many times when a jam is removed the tab is broken off or the lever is pulled out of position. Hopefully you can take advantage of the one year warranty..
Jul 14, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Copy turns on but unable to make copy
Hello sir;Check the paper tray, pull out paper tray may be have a paper hanging there.
Jun 13, 2009 | Canon PC-920 Black and White Copier
Hello sir; Go back to wherever you pull out the paper, because you pull the paper in opposite direction therefor pull off the senser,go back where the paper jam put the senser back in right position.
May 30, 2009 | Sharp AL-1655CS Copier
My screen says unable to init. check manuel
Try cleaning the rollers located around the paper feed and making sure there is no obtructions in the way of the paper.
May 07, 2009 | Brother MFC-5840CN All-In-One InkJet...
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
53 people viewed this question
James Cagle
James Cagle
Jim Keysor
