Where the antenna plugs into the back of the tv. This part was broken off. How do I replace it.
  • 8,617 Answers
I would need your model number and also wether your talking about the coax cable or the HDMI inputs for High Def.
Posted on May 19, 2008
Antenna input on back of tv broken off
if your converter box has rca output toy can hook it up that away. Or you can look on ebay for a new main board. very easy to replace. be sure at all time to unplug tv while back cover is removed.........hope this helps
Dec 01, 2013 | Sharp Televison & Video
My out door TV antenna stopped receiving 1 of 8 channels, this station is 20 miles away, the station said they weren't having any problems transmitting, do I need to replace the ohms device?
Is the antenna digital? If not its analog. Most stations are going to digital HD and dropping analog. The other 7 are still broadcasting analog. Ask station if they are still broadcasting analog if antenna is digital. If no, do a rescan of stations in menu of tv. Let me know.
Feb 19, 2013 | Electronics - Others
Antenna in connection is broken
It sounds that the antenna input socket to your TV has broken. Contact any experienced service technician. In most cases, the tuner should have to be replaced.
Aug 16, 2012 | Emerson EWF2006 TV
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Feb 17, 2012 | Standard Horizon Cp180 Chartplotter
Metal prongs on the antenna wire that plugs into the back of my Sirius radio have broken off. Can they be replace?
There are a couple of different ways the antenna connection can break. Docks and antenna replacements are available, though the actual prong itself may be difficult to track down.
Jun 15, 2011 | Xact Communication XTR1 SIRIUS Radio...
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
Broken antenna in jack on samsung lcd tv
Ok pretty easy fix... it has most probably broken away from the PC board, and sometimes the "Old" one can be simply resoldered back into position else... get a replacement Belling-Lee Socket from say.. Radio Shack etc, and simply resolder it back, from where it has become detached from.. it will be obvious when examined, there are only TWO connections, Earth and Centre. Carefully remove the Case, find the spot, resolder/reconnect it back on.. ya good to go.
DO NOT work on it while plugged in! GL.
Jul 29, 2008 | Televison & Video
Antenna part broken and lost remote
Send the TV out for service. The TV tech should be able to replace the broken connector for you.
Jerry G.
Apr 24, 2008 | Orion STV2763 27" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
