Question about Jeep JX-CHR Boombox
Power cord I have lost the power cord, what kind do I need? And where do I buy one? the back of the unit has this # , WRSS-3A/CTV if that helps.
You can go to radio shack and but a COBY universal AC-DC Adaptor Model CA-44 which one of the adapters will fit.
Posted on Nov 26, 2008
I need to find the switch for my Jeep JX-CHR Boombox, i am looking for the on and off switch
Posted on Jun 20, 2009
I lost my 12 V 3A DC adapter for my LG Flatron E2360V-PN What kind is compatible
have you been tried to find at the shopjimmy.com or at the amazon.com?. you can replaced it with other adapter even not LG, the only need to considered is the same voltage and amper rating as will as the size of the output jack and polarity of the adapter you will replaced. which will fit and same polarity to your monitor .
Dec 11, 2012 | Computers & Internet
My Wii console won't turn on.
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
- THEN, buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
When lighting hit and the wii go out what do i do to make it come on
Try the following steps in this order:
FIRST:
SECOND:
THIRD:
FOURTH:
MUST DO:
- buy a good SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 01, 2009 | Nintendo Wii Console
LEFT POWER CORD IN A HOTEL, CAN'T FIND A 9V 3.0A CORD ANYWHERE
Usually where the power cord goes it tells you what kind it is (i.e. 12vDC). From my experience, Radio Shack offers different kinds of cords as well as plugs for the unit that match up with the plug on your player. I'd go there and check it out but bring the unit with you and they will match things up.
Jun 14, 2009 | Durabrand Portable DVD
I LOST THE ANTENNA FOR JEEP WRSS 3A BOOMBOX
I have the same boombox and lost my antenna. I ended up going to my local Walmart and bought a generic rubber moulded car antenna. The studs that came with the antenna had threads and too large of a diameter so I carefully filed/ground the threads down until I acheived the correct diameter necessary for the antenna stud to slip into the antenna receptacle. It works great and looks as if it came with the radio to begin with. I hope this helped!
Apr 22, 2009 | Jeep JX-CHR Boombox
Polaroid FLM-2011 LCD
look at the back of your lcd it usually will state the voltage and power requirements of the required replacement adapter...never exceed the voltage requirements this may cause damage DO NOT USE THE 16V ADAPTER!
The adapter you require appears to be rated at 12V x 5A a 60Watt unit you can replace most likely with similar switch mode unit rated at 12V and at least 5A or more
Aug 25, 2008 | Polaroid FLM-2011 Television
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Feb 09, 2008 | Durabrand Portable DVD
Where can I get a new charger, I lost mine
You can try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger for the TruTech PVS12701.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701. (am guessing crown type center positive, pls confirm with the store. It may also help to bring along the unit when doing the purchase over the counter)
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | TruTech PVS12701 Portable DVD Player
Jeep JX-CHR Boombox Logo
376 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
