Question about HP vs15 15"LCD Flat Panel Monitor
LCD TV Acer is fading out
Please, I need your help to find out what's wrong with my TV that is fading out and it's only poorly visible with the maximum graduation for bright and contrast.
Thanks in advance
Javier
javier66cu@yahoo.es
  • leroylll Feb 18, 2009
    my phillips lcd tv picture fades but the picture is viewable and there are light verticle lines across the entire screen. It also keeps ghost images of the last viewed screen when changing the channel
    Sergeant:
    Champion:
  • 274 Answers
If what you are saying is the screen shows up and then goes dim or starts dim, and you can see a dark image (maybe reddish in tint)...
Your problem is a bad CCFL (Cold Cathode Fluorescent Lamp) at the top of the LCD panel.
You can find many websites that sell these parts, but make sure you have the right model.
If you feel comfortable with working on components, you can replace this part yourself. Otherwise, you may want to pay a technician to do it. Make sure to get a fixed price quote before authorizing the work.
Here is a website on LCD repair for laptops, but it the same principal for most LCD displays (TVs).
http://www.ccfldirect.com/lcdtutorial.html
RDO
Posted on Nov 17, 2008
I have taken acer lcd monitor on march 16 2008, the power to monittor is goning to on and off frequently while running..? and monitor is on and off itself, when it is start acer symbol is coming...
2 years old may be due for bad DC filter caps inspection which is very common failure on LCD TV's and monitors.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 18, 2011 | Acer 19" LCD Monitor
How do I open this monitor to get inside and see what is wrong Acer AL2016W B
Remove the stand and all the screws in the back, then use thin flat blade screw driver to crack open the case starting at the bottom rdge and work you way around.
Service manual:
http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL2016W&kategoria=&kat2=all
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER (http://s807.photobucket.com/albums/yy352/budm/ACER/) monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
May 13, 2011 | Acer AL2016W 20" LCD Monitor
The off/on button is stuck on.
You will have to disassemble and reseat the push button assembly, it is very poorly design.
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20X223W/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Apr 24, 2011 | Acer 22" X223w LCD Monitor
Hi! My Acer al1751 lcd monitor has following problem: In startup power comes on, display flashes twice, then goes off. On windows desktop picture is visible about 1-2 seconds, then monitor goes to stand-by...
It odes the same when attached to another PC/ We just want to make usre it is not PC problem.
I would suspect the caps first.
Please download the service manuals so you will know how to take it apart.
Service manuals: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=al1751&kategoria=monitor&kat2=schematics
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Jan 11, 2011 | Acer AL1751B (Silver, Black) (Black,...
My Acer X193W when I turn it on, it turn on but then turns off automatically..I can see lines and the brand Acer appear before it turn off.
Please read below and check the power supply caps first.
Please download the service manuals so you will know how to take it apart:
http://elektrotanya.com/?q=showresult&megnev=acer%20&megnev2=x193&kategoria=monitor&kat2=schematicshttp://elektrotanya.com/?q=showresult&megnev=acer%20&megnev2=x193&kategoria=monitor&kat2=schematics
Jan 11, 2011 | Acer X193W LCD Monitor
When turned on, the monitor went blank (or black). Have re0boted PC and no change. We replace the LCD monitor with another one, and it works. What could be wrong with Acer AL1916W LCD Monitor that we...
That is old enough to have bad caps by now, that will be the first thing to look for.
Nov 29, 2010 | Acer AL1916W 19" LCD Monitor
I'm having problems with a X203H. When windows desktop loads the monitor shows the desktop for about a 1/2 second then fades and goes blank. It repeats this when I turn the monitor off then on again. I...
If you read below, you will know that common problem in failed monitors are due to bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Basic LCD monitor troubleshooting guide:
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 24, 2010 | Acer Computers & Internet
My screen fades after 3 seconds after it was switched on
It can be the problem in the backlight inverter circuits, you will need to open it up and inspect the inside. Please see my pictures here to get some ideas what to look for inside:
http://s807.photobucket.com/home/budm/allalbums
Hopefully it will be bad lamp assemblies. For 15" monitor, I would not take it to repair shop, it will end up costing you at least $50 and more, use that money toward new monitor instead.
Apr 15, 2010 | Acer AL1511 15" LCD Monitor
My monitor has gone from a beautiful, sharp screen to one that is faded and blurry. It is only about 6 months old. Is there an adjustment that can be made?
Hello Katherine ann, hi, the faded and blurry picture is usually caused by poor LCD panel connections, due to loose contacts and screws. This is usually poor ventilation, or factory defects. Since you mention its only 6 months old, it is still cover for warranty, call your dealer for service.
Mar 24, 2010 | Acer 22" X223w LCD Monitor
No Backlight when powered up Acer 5610.
Mine does this too. It is the inverter. Of course it goes wrong as soon as your warranty expires. It can result from Best Buy sending you the incorrect battery and them insisting to put it in even though the voltage doesn't match...
You need to replace the inverter. This page should help:
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Jan 13, 2009 | Acer Aspire 5610-4648 Notebook
HP vs15 15"LCD Flat Panel Monitor Logo
209 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
