Question about Philips PM3S Remote Control
Remote control codes for Symphonic tvcrg13
I have the Symphonic TV/VCR combo #tvcrg13 w/o the original remote. I need the remote codes in order to get to the menu options, as there is no other way into them. Do you know of a universal remote that would work with this model? I have 3 multi-brand remotes that came with other a/v componets but none seem to have a code for it.
  • aztony May 19, 2008
    I mistyped the model of the tv/vcr, it is Symphonic TVCR13G1.
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 19, 2008
  • Swilin Sampson
    Swilin Sampson May 19, 2008
    Try 0171
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
Need instructions for codes for jumbo remote for symphonic tv with vcr
Hello
Setup code for Symphonic TV/VCR with Jumbo remote control is: [002].
There is no setup codes for TV/VCR combo with RCA RCU600M remote control. OK.
Aug 14, 2011 | RCA RCU600M Remote Control
Need to program a symphonic tv with a oneforall remote urc-4021boo
Hello
Setup codes for Symphonic TV with One for all URC 4021 remote control are:
0180, 0171
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
OK
Jul 26, 2011 | One For All URC-4021 Remote Control
Sirs and mesdames: I have a Symphonic TV/VCR COMBO model # TVCRI3E1. The remote control part # (UREMT32SR007) is missing. Where can I find a replacement? Thanks, Ilia Rivera
Hello
Just buy one Philips Universal Remote control Model number [CL 034]. You can synchronise it with your Symphonic Combo by entering one amoung the following codes. Proceedings are also given.
Note: Switch OFF and Switch On your combo, before entering each code.
Three digit codes for Symphonic are:-
033/ 053/ 189
Four digit code for Symphonic TV/VCR combo is:-
0227
Four digit remote codes for Symphonic tv are:-
0053 0189 0227 0456 0024
Four digit codes for Funai are:-
0051 0189 0053 0227 0456 0042
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
You can also check according to the catelogue of that remote control also. The above given numbers are most common for all universal remote controls. OK.
Dec 24, 2010 | Funai Televison & Video
I need the code to reprogram my Symphonic tv/dvd/vcr with a GE Universal Remote 24944
Symphonic tv codes are 0053 0189 0227 0456 0024
tv/dvd combos 0456
dvd/vcr combo 0456 {0458 & 0227}
{0899 & 0236}
hope this helps if not i can scan the code list for you
Jun 16, 2010 | Universal Remote Control GE174Universal...
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
In need for remote code number(s)
Yes I have solved my problem. Thank you very much for the help. I came across a web site that gives you the TV codes so I can program my Direct remote.Thank you again.
Mar 31, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
Remote code
I NEED OTHER REMOTE CONTROL AT POLAROID TBX-2000AF 20 IN TV/VCR/DVD COMBO. THANK YOU
Mar 22, 2008 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Philips PM3S Remote Control Logo
1,057 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
