These types of severe cartridge
errors (i.e. "refer to documentation" / "incompatible cartridges", etc.)
typically indicate the internal micro-electronics of the HP #60-61 cartridge
are electrically damaged. The cartridge's electrical wire runs at rear and
lower side of the ink cartridge, are very delicate and are somewhat susceptible
to ink attack over time, which can lead to premature failures. In addition, the
older the cartridge the higher the chance of an internal electrical failure due
to prolonged ink exposure and subsequent circuit corrosion. I suggest you
always run a 'Tap 41' diagnostic test to check cartridges electrical health
(this is a forced test); you may also bypass the error (temporarily) on C4600-C4700
models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below: HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors &
Warnings: http://www.youtube.com/watch?v=BskAfa6NJSg HP Photosmart C4600 & C4700 Printers - Diagnostics Tap
41 Test: http://www.youtube.com/watch?v=ghxjLCn07Jo HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge
Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap
41 Test: http://www.youtube.com/watch?v=m-OM09NvNqg HP Deskjet 4200 Printers - Diagnostics Tap 41 Test: http://www.youtube.com/watch?v=16uXSBwTan8 HP Deskjet D2500 & D2600 Printer -Tap 10 Diagnostic Test:
http://www.youtube.com/watch?v=RTFOBtdthAc
If you need to purchase a new ink cartridge, we suggest you try a remanufactured ink cartridge fromhttp://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating (free shipping for all orders above $20). For any additional questions please contact us directly: [email protected] -Thank you
How to clear cartridge jam of hp photosmart c4700?
For any
severe cartridge error related message, on the HP C4600, C4700 or D110a printer
models, I suggest you run the internal Tap 41 diagnostics test which will tell
you the electrical health of the ink cartridge - in many cases the cartridge is
internally electrically damaged and will need to be replaced. In addition, you
can temporarily bypass an 'incompatible cartridge(s) or Missing/Not Detected
error message by performing the Cartridge Error Bypass procedure...refer to two
Youtube videos on how to do this:
Tap 41 Diagnostic Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
Low Ink Warning and Other (i.e Incompatible
Cartridge) Errors, HP 60 & HP 61 Ink Cartridges:
are electrically damaged - now, these errors can be bypassed on select printer models (temporarily). The cartridge's electrical wire runs at rear and
41 Test:
