Question about Lexmark X85 All-In-One InkJet Printer
X85 lexmark Everything copied or printed gets jumbled together. for instance, the first and second sentence print over each other on the same line. I've already cleaned the roller and paper rack. Is there anything else i can do?
Under file menu find page setup. Check the margin settings. Compare them to the ones that are in the printer properties. If they are different the jumbled characters are caused by conflicting settings. Try returning to defaults. If this does not solve the problem, check to see what fonts you are using. A page written in a font not supported by your computer will usually display with small boxes or crazy looking characters.
Posted on Aug 23, 2008
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
Lexmark 510 series printer will print one job,
Hmm...Likely a driver issue. Try downloading a new driver (more up-to-date. Remove the old driver first (Need help? Look on the net for 'Removing Printer drivers') I suggest unplugging the printer before installing the new driver as well.
Here is the driver site:
http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&productCode=&segment=DOWNLOAD&question=driver+for+lexmark+510+printer
(Hint: Copy the whole link to notepad, make it all one long sentence, copy again and past into your browser)
Lexmark uses a dedicated 'Print spooler' that may be having issues. Ask a techy friend for help with this.
Mar 20, 2010 | Lexmark Z515M InkJet Printer
When selecting a printing task,If I ask for one copy,the machine continues to print even after hitting the cancel printing. Second*lets say there are two pages to be printed the first oage will print,the...
Hello. Try to unplug the printer from the power outlet for about 10-15 seconds to refresh itself. If that doesn't resolve the problem, it might be software communication issue. You can uninstall then reinstall the software. If you're computer is running on Windows, uninstall by going to Start Menu > Programs/All Programs > Lexmark Series folder > Tools/Uninstall. Reboot pc. Reinstall software. If your using Macintosh, go in the Lexmark folder and Uninstall. Reinstall software. Hope this helps.
Mar 17, 2010 | Lexmark C533DN InkJet Printer
Printer
Click on start, programs, lexmark x85
Click the "cartridges" tab and check the ink levels.
You may have to allign the print cartridges to set the color up correctly.
http://www.lexmark.com/publications/pdfs/x85/en/user.pdf
Apr 20, 2008 | Lexmark X83 All-In-One InkJet Printer
Print Output
Try cleaning the feed rollers. these are the rubber wheels that actually contact the paper and pull it through. If they get dirty, their grip on the paper will be less than adequate. Just use some clean water, or perhaps some rubbing alcohol, and a clean rag to wipe them thoroughly.
Feb 11, 2008 | Lexmark X85 All-In-One InkJet Printer
Lexmark x85
You didn't specify which operating system you have.
If you have Vista, people have reported success using the Windows 2000 driver.
Drivers can be downloaded from here:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X85
Feb 09, 2008 | Office Equipment & Supplies
Double printing
This one is too lenghty to give you here, goto lexmark.com, and in support knowledge base, search with this line...blurry, fuzzy, or double print from a lexmark x4720...There is specific info on test pages you need to run to narrow this down.
It could even be a conflict with motherboard/proccessor that can occur with some e-machines, compacs and others using certain amd chipsets
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
System error 000 carrier stall Presss power Key
Does carriage bash against side when power up? if so encoder strip is dirty or incorrectly seated... plastic strip inside printer lines on it 1cm wide, must sit vertical in slot on carriage
Might be somethin stopping print head from moving along rail, check ink carts are installed correctly and fully, check for paper squashed up left and right inside ends of printer. make sure carriage moves left and right
Try power up without cartridges and just black and just colour cart to eleminate cart faults does error change?
Oct 19, 2007 | Lexmark X85 All-In-One InkJet Printer
Lexmark X85 All-In-One InkJet Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
