Question about Goldstar R6004 Air Conditioner
Wiring diagram for a Goldstar A/C R6004
Where can I find a wiring diagram for a Goldstar in window A/C unit? My friend pulled her power cord out by accident.
  • dannykaye20 Jun 21, 2008
    i called gold star and they were not very helpful they stated that they could not help me with this problem if anyone could send me a wiring diagram it would be great i just need to know where the black and white wires go on the ac unit.
  • 145 Answers
If you remove the cover it should be on a sticker in the control area. If it's unreadable you will need to contact the Goldstar.
Posted on May 19, 2008
Kelvinator wiring diagram for wall mount air conditioner model ewh09hra
Good Morning Friend,
I understand that you are looking for the wiring diagram for your Kelvinator air conditioner, model# EWH09HRA. Typically, the wiring diagrams are not readily available. I suggest contacting the manufacturer, and have your model number available for them. They might be able to locate a copy of the wiring diagram of your air conditioner for you. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Electrolux Heating & Cooling
Power cable is out of Air Conditoner what to do in this case?
Hi, if the unit fell and pulled the cord out, all you can do is to wire it back in. The unit is probably 220 volts, so it will be fairly easy to do. Look at the wiring and see where the wires have come off. All you have is 3- wires and a ground. Look at the wiring diagram, and it will show you exactly how to do this.
Shastalaker7
Jun 09, 2011 | Goldstar LG L1004R Window Air Conditioner
I replaced the power cord on a carrier ac window unit 24000 btu model yc-d , now the compressor will not shut off regardless the thermostat setting
You have probably one wire in the wrong place on the back of the switch. There should be a wiring diagram near the electrical compartment on the window unit. It will show you where the wire needs to be. You are probably just a terminal off.
May 01, 2011 | Heating & Cooling
Need wiring schematics for Haier HWR12XC5 AC
My friend ... you are doing a simple repair ... you don't need a wiring schematic to replace this power cord. When you get the unit open ... you will find the other end of the ripped cord ... black goes to black, white goes to white green goes to green or ground. In fact ... you will trim the end of the cord and reattach it using either crimp connectors or wire nuts.
Thanks for your interest in FixYa.com
May 31, 2010 | Heating & Cooling
Wiring for Goldstar R5050 window A/C
Yes I accidentally drop my Gold Star Model #R5050 out the window while installing it. I opened it up and the two(2) white wire are off and I don't know were they go. I try to connect the to the empty terminals and I got a spark out of the outlet. Can you please help me....
May 13, 2010 | Goldstar R5050 Air Conditioner
Wont shut off
greer appliance parts, tulsa ok 9185873346
May 05, 2010 | Goldstar R6004 Air Conditioner
Goldstar R6004 Compressor problem.
Should be the start kit (black plastic capacitor and relay). When the ac shuts off if the pressures don't equalize, then the start kit gives the compressor additional starting torque to start the compressor during uneven load conditions.
Aug 18, 2009 | Goldstar R6004 Air Conditioner
Driver side power window shot
Sometimes on older models, the wiring between the door and the pillars is broken,
Pull the rubber cover over the wiring between the door and the pillar and inspect for broken wires. Even if you had power to the motor, when you close the door, there’s a possibility that the broken wire moves and losses connectivity
Let me know, Pierre ( Montreal )
Nov 24, 2008 | 1992 Honda Civic
Goldstar R6004 Air Conditioner Logo
778 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
