Question about NetGear WGR614 Wireless Router
Network Cable Unplugged
I connect to the internet thru a modem which is connected to the Netgear router which in turn is connected to the desktop computer. network connection between the laptop and desktop has been fine, until two days ago. Laptop is not receiving the router signal. It says that network cable is unpluged and wireless network connection is connected.
  • chelliepooh May 20, 2008
    I am only able to connect to the internet (on my laptop) if my wireless router's ethernet is connected to the back of my laptop. Wireless means that i should be able to use my computer without a ethernet connection right? I desire to use my laptop in other areas of my house; but i'm not able to. Can you help me? I have a NetGear WGR614 wireless router.
    Problem Solver:
  • 8 Answers
Mairelina, if all was well 2 days ago then resetting the router should fix your problem. usually a small button on the back of the router.
chelliepooh, you need to check that the router's wireless function is on. connect using the ethernet and go to the config page (usually make sure wireless is on and security is set to wpa-psk.
Posted on May 30, 2008
Why cant i get wifi or wireless internet to work
depends on how u r hooked to internet. direct thru cat5 cable to modem, or wirelessly thru router? then, you must make sure that your modem is connected to web? make sure modem is connected; plug in to desktop(off) then turn desktop on; go to start, then control panel, then Network and Internet; find out if you see a connection? if so, then right click on network connection, click on Troubleshoot Issues. this will try to resolve your internet connectivity. if you still cannot get online, call your internet provider for more specific steps in fixing.
May 16, 2014 | Dell XPS 200 PC Desktop
I cann't connect to some specific web when using the NetGear router. I never have this problem before. I have try bypass it by connect my internet directly to the modem then the web get in is ok, by when I...
a lot of times its the sequence of the reboot for each device. what happens is, the modem connects to a particular device (computer, router, etc.) and then establishes that connection as a relationship. if you try to plug the ethernet cable into a different device without rebooting the modem, it will never connect. that being said........make all of your connections modem ethernet to router input, then router output to computer ethernet input. then, reboot the modem (with no power plugged into the netgear...its next, just no power yet). once the ready or cable light goes solid and the modem is up, plug the power supply into the router and let it do its thing, then you should see the "i" with a swoosh under it light up, it will be orange for a bit until it connects to the modem, finally turning green. from the router to the computer your start button on your desktop, click the "run" near the control panel button....a little window pops up down by the start button....type the letters cmd (short for command) and then hit ok screen for dos pops up with a blinking curser.......type ipconfig then hit enter. the first stages of numbers for the default gateways etc should read close to this (this is the ip of the router). if you see these numbers, you should be able to surf the web. you must do the reboots in the sequence as stated above.. give each interval a minute to do its thing. some newer operating systems need you to physically acknowledge the "new network detected" and select home away office...... so once the reboots and the ipconfig stuff is done but you still cant surf, restart the computer, hopefully when it comes back on it will detect the new network.
i am a senior tech for charter cable and have installed over 5000 internet connections.
you can also email me thru my website for further questions.
Jan 21, 2010 | NetGear RP614 Router
Can't connect to internet on desktop computer
Most likey the issue is with the network adapter. As it does not work even with the modem and router the card seems to be faulty.
Hope this helps.
Sep 05, 2009 | Computers & Internet
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
No network detected to setup wireless router
You have to set a network connection on the computer. Go to the control panel and chose Network, the set a new one.
Jan 06, 2009 | Computers & Internet
Connection issue
put the blue cable connection with the router and cable modem first.configure wireless setup.put the desktop rj45 connection to a free router rj45port.As u are getting internet on wireless check the desktop ip configuration.obtain auto ip configuration should be clicked.
Jun 28, 2008 | NetGear FS605 - 5-Port 10/100 Network...
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Sep 15, 2007 | Actiontec GT704WG Wireless Router...
NetGear WGR614 Wireless Router Logo
175 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
