Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Purple pictures Help! When I 1st started using my AiO the pictures were great! I can't seem to get the yellow to print now. Have put through the test page--no yellow.
  • Anonymous Jun 03, 2008
    red ink won't print
  • 34 Answers
Remove the cartridges and the printhead
reinstall those
do a deep clean by going to menu>clean printhead
then try to print a demo sheet if still fails
contact 1 800 421 6699
Posted on May 29, 2008
Lexmark x2600 printer; color looks great for 1st 2 inches of printing then changes; green went blue, yellow went white, red to purple.
Your cartridges may need to be cleaned. Open the Lexmark Solution Center and select Clean to fix horizontal streaks. This will force ink out through the cartridge nozzles, cleaning it from dirts and clogs. This will improve print quality on your printer. Also, make sure you are using genuine Lexmark cartridges to achieve high quality results.
Apr 08, 2011 | Lexmark X2600 InkJet Printer
Yellow not printing properly.
Go to the maintenance section of your printer on your desktop and clean the cartridges
Start - printers or Start - control panel - printers
Also check the level of your ink while you're there
May 08, 2010 | HP Deskjet D2360 InkJet Printer
Have a dell 942 AIO. graphics in grey seem to print purple
what OS are u using ?
U may will have to unistall the driver Again ( make sure that the printer is unplugged) . run Patch .. ( Available at support.dell.com )
Reinstall the Printer drivers again ( downloading from Dell Website .. install them ( make sure that the cable is connected only when Prompted ) )
This should resolve the Problem
Mar 20, 2010 | Dell 942 All-In-One InkJet Printer
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
Black and Magenta ink won't print...
Do a deep clean on the printer.
Done from the printer setup.
widows is done from start, printers and faxes, click on your printer.
Should bring up window for setup.
Look for cleaning section.
May 07, 2009 | Epson Stylus C88 InkJet Photo Printer
Hp pro b8350 will not print colours seen in pictures
discovered print cartridge was faulty. no yellow was coming through.New cartridge solved problem
May 01, 2009 | HP Photosmart Pro B8350 InkJet Printer
Picture prints have no yellow, purple tint
I've solved this with multiple head cleaning. I cleaned the print heads 7 or 8 times and it's working ok again now.
To clean your print heads do the following:
  1. On your computer, start the KODAK AiO Home Center.
  2. If the Help toolbar is not open, click the Help (?) icon in the upper-right corner of the window.
  3. From the Help toolbar, select Maintenance.
  4. Click Printhead Cleaning, and wait for the printer to complete the cleaning.
hope this helps
Matt
var solutionBaseUrl = '/service/main.jsp?t=solutionTab&ft=searchTab&ps=solutionPanels&locale=US_en&_dyncharset=UTF-8&solutionId='; var transactionFragments = document.getElementsByName("transactionFragmentForm"); var solutionLinks = document.getElementsByName("solutionLink"); atgss_loadFragments(transactionFragments); atgss_modifySolutionLinks(solutionLinks);
Mar 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Error message 1102 when i put cartridge # 33 back in
Overview
The 1102 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In-One (AIO).
The procedures in this article will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark below.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5
Insert the color cartridge. Close the top cover, reinsert the power supply, and power on the AIO.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7
Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges and clean the cartridge contacts
Mar 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
