Question about Dishwashers
Hub nut and strainer basket
Dishwasher leaks water all over floor and water is left standing in bottom of washer. was wondering if perhaps the strainer basket could be clogged but don't know how to remove the hub nut to get to it. HALLLLPPPPP
  • 868 Answers
Call a service tech!
Posted on May 20, 2008
Leak at new strainer waste fitting
Did you put the rubber gasket and cardboard sleeve on the bottom of the sink(next to the nut and did you use plumbers putty on the top part of the sink under the top section of the basket. Hint if you put some soap on the gasket under the sink between it and the nut it will be easier to tighten also you must secure the top part of the basket as you turn the nut if not the plumbers putty will not seal. If you do not have the strainer basket holding tool wrench you can substitute with a pare of needle nose pliers. Large channel locks or pliers can work to turn the large nut on bottom. If you can recruit a helper to hold the top part of the strainer basket with the needle nose pliers it make the job of tightening the large nut easier. When a large amount of the plumbers putty has squeezed out and the strainer is flush with the sink you should have a tight seal.
Feb 24, 2012 | Blanco Plumbing
After top washer is through washing there is a little water left in the bottom washer also most of the timeit leaks a small amount of water on the floor on the left corner of the dishwaher
This problem will require a service person to correct, you may have a water dispenser problem in the door and a check valve problem with the lower drawer. Water on the floor is a bigger issue, Look at the drain line to assure they have no leaks, they are black and white hoses that hook up under the sink. If the drain system is fine, is the water on top of the lower control cover? Each drawer operates different from each other, so you would need to determine which unit is leaking. I have part numbers and service manuals if you want them.
Good luck, I help this is helpful.
Jul 11, 2011 | Fisher and Paykel 23 in. DD603H SS...
While on vacation our house had been checked at one week later &again 2 weeks later, @ 3 weeks check, floor in front of dish washer & entire kitchen had standing water , as DW door was opened...
Take a long shot. Say your mains leak a little, quite possible, and you machine's inlet solenoid valve leaks a bit, say about a litre a day - you probably would not notice it during the normal course of events, in a week it would leak about 7 litres into the machine, in the second week it would have about 14 litres in it, about at the level of the door and not seen by the house visitor. The next week it would leak another 7 litres - all over the floor. Now it would be noticed?
Mar 07, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Hoover Dishwasher HD95M leaks on start up from bottom right front corner. Leaks when initially being fed from water feed.
Water leaking can be poor plumbing or fault in the inlet hose connection. You are the first observer and so your view on the leak area is important as the leak can be from the hose, from the inlet, the hose or the washer unit.
Based on this the water leak can be plugged, tighten the hose clips, check the inlet filter or check the washer's feed line.
Feb 09, 2011 | Hoover HD95M Free-standing Dishwasher
My badger 5 plus 5/8 HP HD insinkerator is leaking from the bottom of the unit. It is dripping from the reset button and one other metal tab location. It is at least 10 years old. Can it be repared?
Sorry to read about your problem, I hope this helps you out.
sorry no it is rusted out, even if you could take apart, after 10 years 1/2 the parts will be rusted..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.
Thanks and good luck. you are looking around $90.00 for a new unit
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My in-sink-erator model 5-81 is just over 2 years old and is leaking from the sides whether it's running or not. Is there anything I can do or do I need to contact a professional>
Find out exactly where leak is coming from.
You say water is coming from the side... is that where the pipe connects? Then take apart pipe and reassemble pipe using instructions below, and use rectorseal on joints as described below..
Is water coming from where dishwasher connects to disposal? Then tighten the clamp.
Is water coming from top where disposal connects to sink? Run paper towel around top to check for moisture, and then use steps below to dissemble disposal and re-install same disposal.
Is water coming from a rusted hole in disposal. Then replace disposal using steps below:
Here are the disposal steps:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or change pipes.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment
Dec 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply rectorseal where lower p-trap comes together.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking from the bottom after removing something that got stuck in the spinning peace
Check a couple things.
Use paper towel and see if top of disposal is damp or wet. The basket strainer might have come loose and water is leaking down.
Fill sink and then release water all at once and check strainer basket and dishwasher hose.
Check where tubular pipe connects to side of disposal. Sometimes this joint can leak, and then water appears at bottom of disposal.
If top of disposal is dry and tubular pipe is not leaking, then disposal is suspect.
Disposals rust out, and dislodging something from cutter plate can open final crack.
If basket strainer is leaking, and disposal is older than 5-8 years, you might consider new disposal since disposal has to be completely removed to reseal basket strainer. See link below for basket strainer steps.
If it comes to this, I wrote tips for installing new disposal
http://www.fixya.com/support/t6995519-badger_1_2_hp_in_sink
Nov 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1/2 hp in sink erator (garbage disposal) steady stream leaks from the bottom near the reset button. It appears to be coming from a drain outlet (a small hole, dia. approx size of smallest screw ),...
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
Disposal will need to be replaced at some point.
That way we didn't have to change out sink basket.
Nov 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwashers Logo
144 people viewed this question
Top Dishwashers Experts
