Installing motherboard in gateway profile 4
Hi. i tried to install new memory stick in my profile 4 but i had the power cord connected. now the computer will not come on. i tried the old memory stick and still the computer will not run. we tried to run the computer with NO memory in it and the fan comes on for about 3 seconds and then stops. have i damaged the motherboard or the memory sticks or both?
also, how difficult is it to install a new motherboard in a profile 4?
anything else that i could have damaged?
thanks,
paul
You need to replace the motherboard if the pc is auto shutting off, maybe even the processor!
Posted on Sep 09, 2009
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
Gateway Laptop MC8741 will not turn on. Replaced battery....replaced power cord. Noticed that fan was not working a day prior.
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sep 23, 2010 | Gateway MX8741 Notebook
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
My HP a420n won't start after replacing cd-rw drive
Please try to remove all the connections from your computer and also connections inside the motherboard, the power cord for your hard drives and also the power cord from the power supply to your motherboard.After that, remove the memory and clean the pin by using an eraser of the pencil. And then insert again the memory stick and connect all the connections from the power supply to motherboard and everything. Lastly reset your bios and put it back to normal again. Hope this would help. Thanks..
Oct 22, 2009 | Computers & Internet
MSI x48c mobo keeps powering on and off. Won't post. No video signal. Video card and power supply and memory are all new and all work in other computers.
your motherboard is bad. Try the following before RMA'ng it.
1. Remove all the cards and memory.
2. Recheck your power supply connections
3. Remove, clean the thermal paste and reapply new
thermal paste (follow the manufacturer's directions)
4. Reseat the CPU.
5. Install one stick of ram
6. If the motherboard has an onboard video connect your monitor to it.
7. Try powering it up.
If that works, add the rest of the memory a stick at a time. If the system continues to power up, then install the Video card, and test again. Finally if everything is functional, chalk up the previous problems to bad karma. If the system fails to power up, and stay powered up after adding a component, then that is the faulty part.
Oct 13, 2009 | MSI X48C Platinum - Socket 775 for Intel -...
The green power light is on but nothing happens,its a gatway prof
MAYBE IS A BAD MOTHERBOARD SEEN THE PROFILE 4 HAVE HISTORY OF MOTHERBOARDS GOING BAD BUT YOU CAN HAVE SORE IF YOU FIND A NEW MOTHERBOARD AND CHANGE ALL THE COMPUNETS TO THAT MOTHERBOARD AND TRY TO BOOT UP IF IT BOOT UP SOCECEFULL IS A BAD MOTHERBOARD
Oct 08, 2009 | Gateway Computers & Internet
Computer will not boot
Hi Zany913,
3 and 4 solid green lights indicate that the memory is detected but there is an error. First reseat the memory modules. Then try one at a time.
If nothing happens, I'm afraid you'll need to call dell for replacement RAM.
I hope this helps,
Adam
Jul 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Motherboard asus p4vp-mx
Do you have a video card installed or are you using the built-in video? If yes, check the video card if it is installed in the motherboard firmly, first unplug the power cord in the power supply then try removing the card then install it again in the agp slot carefully pushing it firmly, then put the power cord back to the power supply and try to power it on. Does it have a display now?
If the video is still blank try reinstalling the memory module in the motherboard, first turn the pc off then unplug the power cord, next remove the memory modules from the motherboard by simultaneously pushing locks on each side of the memory, then use a clean paint brush to remove any dust on the memory modules copper contacts and also clean the memory slots in the motherboard, then install the memory back to the slot making sure to match the notch near the middle of the memory to the memory slot in the motherboard, and also make sure that the locks on each side is firm. Then connect the power cord to the power supply then turn it on. Does it have a display now?
In the condition where your using the built in video and a known working memory and still there is no display, the motherboard could be defective already.
Jun 18, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
