Question about Sony Playstation 3 (PS3) Console
Ps3 setup I just bought a pS3 40 gb. I plugged the av cable into the back of the tv. When I turned on the system, the first screen is red and constantly rolls from left to right. any odeas?
Make sure you have the video cable in the video in slot instead of the video out
Posted on May 20, 2008
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
Hi, please please please help..... I have just bought a new Panasonic 42 Inch Full HD 1080p Widescreen LCD TV TX-L42U2B from Argos, I also bought the HDMI cable they recommended on the same website...
hello chis, it may the ps3 your having trouble with connect ps3 to hdmi 1 reset the ps3 by doing this. press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button this will reset the display setting on the ps3 you should get1080p if this dfon't work feel free to get back to me thanks
regards
shaun
Jan 08, 2011 | Sony Playstation 3 (PS3) Console
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    No audio or visual via AV Cable
    turn the power off in the back and then turn hold the power button in on the front then turn it back on in the back and continue to hold the front power button down for 5 seconds and you should here a beep then let go. Then turn it back off then on
    Apr 26, 2009 | Sony Playstation 3 (PS3) Console
    Stuck on hdmi
    Just plug the AV cable in as normal. The PS3 auto-detects the AV cable. Turn your PS3 on first, then your TV. Change the channel on your TV to your AV channel (YPBPR) and it should come on fine.
    Feb 21, 2009 | Sony PlayStation® 3 (60 GB) Console
    My ps3 has no picture or sound...
    if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
    Jan 22, 2009 | Sony Playstation 3 (PS3) Console
    Hd tv as no hdmi plug
    There are PS3-components cables available out there (the Red/Green/Blue one) you can use to connect your PS3 to your TV and still get HDTV on your TV system. You should be able to get it where you bought your Playstation. Got one for 39.99$ CAN
    Cheers
    Dec 22, 2008 | Sony Playstation 3 (PS3) Console
    PS3 will play on AV but will not in HDMI
    1. Connect via AV and turn on the system.
    2. Go to Setting and then Display setting
    3. Select the connector type on your TV.
    4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
    5. Your TV Screen should be on via HD cable
    Dec 09, 2008 | Sony Playstation 3 (PS3) Console
    Nothing appearing on the screen
    you need a scart box the one that you put the yellow red white plugs in to then you put it in the back of the TV than go to av on the TV remote that normally works on new and old TVs
    Jan 03, 2008 | Sony Playstation 3 (PS3) Console
    Ps3- hdmi to av
    unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
    Aug 24, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    41 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
