Question about Intel D945GTP Motherboard
Computer stopped working - I see a spark when I plug onto motherboard
Just stopped working. Powersupply is ok. I disconnected all power and other plugs and systematically plugged them back in.
Wehn I plug in the square block (2x2), into that square input that sits just behind the big purple dohicky below the video input, I see a spark and then the computer stops working.
Anyone have a similar problem? And a solution (of course...)
Thanks!
  • Philsy May 19, 2008
    Thanks - is this the kind of repair you need to have done at a repair shop or cna I just get a new MOBO myself and install it? My board is an Intel D945GTP - can I upgrade to a better board, or is that even feasible?
  • 593 Answers
The spark you see is a shorted power socket on the MOBO, the spark is shutting down the power supply for protection. You need a new board.
Posted on May 19, 2008
  • Steven Wander
    Steven Wander May 20, 2008
    I saw one for sale in stock for $250, yikes! I saw another post that says if you power down for 3 hours with no P/S plugged in, it might come back up. Just unplug cord to P/S and then hit the power button for 7 seconds to discharge board capacitor charge. Do not unplug any drives on this board with P/S plugged in, it senses a voltage difference and shuts down!
Hp iq526 no power
using any multimetr test PSU if OK, then disassembly laptop housing plug PSU in power socet and test power output from power socet to motherboard, iuf OK then look for fuse near power socet on motherboard and test it
Nov 13, 2012 | Computers & Internet
Every time i plug the p4 wire in to the motherboard power stop
There is a short somewhere, either with your motherboard or your powersupply. Test your powersupply to another motherboard that has the 4pin 12volt adapter if you have one. Most likely your motherboard is trying to prevent circuit overload to the cpu.
Jan 15, 2011 | Biostar NF61S MICRO AM2 SE...
Optiplex 330 wont turn on shut down went to power back up won't do anything no fans only light is the led on motherboard
your powersupply could of gone bad try to unplug the powersupply and plug it back into the motherboard if this doesnt stop it the part of the powersupplly that tells it to kick on is bad
Dec 12, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
Battery replacement
hi there;
hey try to unplug the power cord from the powersupply now open the case and unplug the powersupply to the the motherboard and then press the reset button on the front for 15 seconds and than connect the motherboard powercable and plug in the powercord back in to the powersupply and try to restart the computer. please tell me if this works and ANY thing that happnes ok best regards mike
Jan 28, 2009 | EliteGroup P4VMM2 Motherboard
Power supply installation in gateway 610xl
to replace a standard ATX powersupply;
remove left hand side cover (ensure power is disconnected first);
disconnect the 20.24 pin primary power plug (big wide white one plugs directly onto the mainboard, also disconnect the 4 pin AUX power plug, looks just like the other one but is a smaller square shaped plug (older P3 boards will not have this)
disconnect all 4 pin power plugs from hard drives/cd drives and aftermarket fans (if any are installed), disconnect SATA power plugs from any SATA devices installed (flat black plug, 4 wires)
disconnect floppy drive power plug (if app) small while 4 pin power plug, once all of these are disconnected, looking at the rear of the computer there will be 4 screws holding the power supply in place, one screw will be more to the centre slightly to ensure you do not put it in upside down, once you remove those screws the power supply will slide right out.. simply re-do these steps in revers for instaling the new power supply
David
Feb 28, 2008 | Gateway Media Center 610XL PC Desktop
Replacing power supply on a gateway desktop 600xl
David
Feb 28, 2008 | Computers & Internet
Not powering up
First test the MB with only the minimal components (ie. cpu + ram + vga card if not onboard). Disconnect all other components. If still not starting, try using just a single ram module, if you have more than one, to try & determine if one of them is faulty.
Dec 25, 2007 | ASUS P4PE Motherboard
Intel D945GTP Motherboard Logo
274 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
