Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dishwasher My dishwasher light just stays on like the problem you had with yours .what did you do to fix it. Is there a way to reset it? I would really apperciate you help > thank you Teresa
    Problem Solver:
  • 19 Answers
Which light stays on?
Posted on Jun 10, 2008
Electrolux Dishwasher model EIDW6105GS1A, heavy light on, won't start. Turned off circuit breaker for dichwasher and the light turned back on and it won't start still. No lights on behind kickboard to show...
Good Morning Kim,
I see that the heavy light is staying lit on your Electrolux dishwasher, model# EIDW6105GS1QA, even after resetting your appliance at the circuit breaker. I also see that there are no lights lit up behind the kickboard, indicating what might be failing. It could possibly be the control board underneath your dishwasher. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing the heavy light to stay lit. I hope this is helpful.
-Best Regards-
WP
Apr 28, 2014 | Electrolux Dishwashers
Dishwasher has to be reset each time I want to run it.
see the wiring diagram: you have a small short circuit. you must call to service tech or electrician for to eliminate problem.Otherwise you will another problem, and so on.
May 08, 2012 | Frigidaire Dishwashers
Dish washer the clean light stays on and the dish washer wont run
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
I have a kenmore ultra dishwasher 655.177779990 and the lock out light was flashing until I unplugged all connectors and plugged back in. Now light stays on and everything else has stopped working. Tried...
You are right, the unit needs a reset. To reset the control you can press and hold the AIR DRY/RINSE ONLY button for 15seconds to solve this issue. Please get back to me if you have any other questions.
Kevin
Dec 09, 2010 | Dishwashers
Dishwasher won't reset, stays on gree-flashing light- Clean cycle
HI,
This is an indication that the water did not heat properly. I have put together some instructions on what can cause this and how to reset the control so you can use the dishwasher again. Follow the link below and let me know if this helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Clean light stays on and will not run on our Kenmore 665 dishwasher.
if you have a whirlpool/ kenmore dishwasher and the clean light is flashing 7 times then pauses and then repeats, it is a problem with the heating circuit.
follow this keypad operation: push the high temp wash, air dry, high temp wash, air dry. this will put the unit into a service mode and it will run a short diagnosis cycle. after it gets done, about 5-7 minutes, then it will reset and allow you to use the unit again.
make sure the water is hot enough at your faucet at least 120 degrees, and the door is getting closed tight.
Jan 18, 2010 | Kenmore Dishwashers
START/RESET LIGHT STAYS CONTINUOUSLY ON
you do not mention the make or model nor do you mention if this was the case since purchasing dishwasher. But before you repost, turn off your breaker to the dishwasher for at least a minute to reset the dishwasher. Hopefully this works. The other options get far more involved and some of them are not for most DIY.
Sep 19, 2017 | GE 24 in. Profile PDW9880JSS Built-in...
New hoover HED 6612-80 dishwasher all indicator lights staying on, manual says due to overfilling with water which is confirmed by water leaking on to floor, how do i solve this problem
hi, i have same problem with my hoover dishwasher same model as your own, did you ever find out how to fix the problem. your help would be really welcomed. thanks lesley
Aug 17, 2008 | Hoover Dishwashers
Lights 4 and 5 stay on
Bad control board.D/w I believe is not worth repairing
Feb 19, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
