Question about Palm Zire 72 Special Edition Handheld
It wont cut on
I have charge the battery for a whole day i did the 3hrs thing first and it still wont come on it only work when it is plug up so let it charge for an other day i really need your help thanks
It sounds like the problem is either the battery itself or the metal contacts inside where you put the battery have become corroded. To replace the battery, you have to take the device apart, which can be tricky. If you buy a replacement battery online, most of the time you will receive instructions on how to perform the replacement yourself. If you don't feel comfortable doing the replacement yourself, then check with some of your local geek shops and see if that's a service they offer.
Posted on May 19, 2008
My battery dies every day and when I plug my phone in it still says low battery
Hi, this is a very common problem with all smart phones they use so much of their battery that the battery life drops really quick the only option you have is to get the battery replaced this will then solve your problem for a while but its not going to last forever, if you go to your nearest phone shop ask them if they have got an heavy duty batteries for your phone, they do make them but are hard to come buy.
one other thing to remember is this, once a month let the battery go totally flat let it go so flat that the phone wont even light up when you press the on button, now do a full charge over night doing this keeps the battery at its best and prevent any bad cells forming so if you do this say once a month or every 6 weeks it will prolong the life of the battery by load so bare this in mind when you get a new battery.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 28, 2010 | Motorola Mobility Q9m Smartphone
My motorola Q charger is not charging my battery.
Sir,
It is your PDA battary problem you are suggested to buy new one as by getting charged it cells get weak by the passage of time.
Oct 15, 2009 | Motorola Mobility Moto Q
K-jam wont charge
The old battery can be made to work by using Jeff-frankenstien USB-cut method.
Just search for the method on the internet, and do the same.
See if it helps to recover your old battery.
Please Rate...
Sep 14, 2009 | i-mate K-jam Smartphone
Blackberry pearl wont switch on
It looks battery completly drained and dead (as It took so much time), the best way first to check "Circuit" status in Battery through Voltmeter (poles)..or another way go to any cell phone shop and give a trial with another batterty to check status of your unit.
Aug 23, 2009 | RIM BlackBerry Pearl 8100
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
Battery problems wont charge
Two things could be your problem your battery could be over charged or your charger is no good take it to any store or cell phone place and let them test it
May 07, 2009 | Pantech Duo Smartphone
Hi there, i have a blackberry rim and cant turn it on, when i plug the cord in to charge it up the red light at the top flashes on for a second then the whole thing goes dead again....help plz and thanks...
It sounds like an issue with the battery. Check the battery is not warped and is genuine. Easiest option is replace the battery.
To make sure it is battery related, Try to charge via USB or another AV charger.
Jan 09, 2009 | RIM BlackBerry Pearl 8100
T-mobile dash wont turn on
In my experience when getting a phone wet your only choice is to let it sit. It could take a few days or a month but soon or later they usually fire back up.
Dec 14, 2007 | T-Mobile Dash Smartphone
Blackjack will not power up even after charging battery
the pins inside the phone where its plugged in could be messed up, that's whats wrong with mine but i found the phone and i don't have warranty or service for it, basically use it for storing info.
Aug 21, 2007 | Samsung Blackjack SGH-I607 Smartphone
My hp rx1950 won't turn on after a while
There could be a piece of software running that is locking up the device. You might want to check for updates to your PDA and any software you have installed on it. If that doesn't work try doing a hard reset, which will erase everything, then reinstall one application per day to see if the problem pops up after one of the applications is installed. If that doesn't work, it could be hardware issue, if there is an extra storage device in it pull it out and see what it does. You will have to troubleshoot. Try different things and see what the result is, eventually you'll be able to narrow it down.
Jun 25, 2007 | HP iPAQ rx1950 Pocket PC
Palm Zire 72 Special Edition Handheld Logo
41 people viewed this question
Top Palm Computers & Internet Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
