Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
well..the control board has this sort of issue. sometimes, if you turn if off long enough to reset itself, this may clear..otherwise, it's a replacement of a non inexpensive component..
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
The picture board on your monitor is bad, since it goes
off after few seconds and the power led or button is on, it means the
board of your monitor has developed fault.
The best thing for you
to
do now is to take the monitor to a local repairer or service center within your vicinity
to help with the replacement of the picture board
because the fault is not something you can fix yourself, in order not to
complicate issues.
Hi
This is perfectly normal for this light to com on and going off after a few seconds. The SRS computer needs to make sure all the sensors and airbags are responding at first ignition key on, then if all of them are responding and working, the light goes off.
If it happens that the light doesn't go OFF after 30secs and stays ON all the times then you should pay a visit to your local dealer.
But for now you can enjoy your car safely.
Cheers,
Technopro
This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
