Question about Brother P-Touch 1180 Label Printer
1180 tape I own an 1180 but have lost the directions. I down loaded the directions at the site but not whena print, I get a tape with no adhesive back. The cassette is lables whit laminated 1/2" with black ink. I get clear backing with black letters and no adhesive . Is this correct or is this for a non-adhesive application? drhck
  • klpmaryk Aug 22, 2008
    Tape cartridge is new and black, white and clear tapes have all separated. Also, when pressing print, only about half of what you wanted to print comes out of the machine to be cut.
  • Suzanne Laging Aug 26, 2008
    I have a Brother P-touch 1180 Label Printer but have lost the instruction manual and need to find one. Where can I download?
Posted on May 29, 2008
P-touch 1180 will not print, I type in what I want and hit print, and I get an error. how do I fix this error, what is the error?!?!
You did not specify the error you are getting. However, if you have an additional TZ cartridge, try replacing the cartridge as the current one may be jammed or out of tape.
Apr 17, 2014 | Brother P-Touch 1180 Label Printer
Owners manual for ct-f1250
music.jpg Popular issues:
  • manual
Problem with Sony CASSETTE DECK Single Dual Cassette Deck
where can i find a sony dual cassette deck tc-w490 manual
Posted by avatar6.jpgbutchdog on Feb 15, 2012
AdChoicesPrinted adhesive We are specialized in printing on self adhesive tapes.
Tissue Leading manufacturer of tissue & biopsy cassettes at great prices!
Solutions (1) Best Solution Hi,
I can give you a link. You can download the service manual of this Pioneer. I hope it will be usable for you.
When you get to the site using the link it is possible that you have to wait a little bit to be able to download.
After waiting you should see a button as "Get Manual" and simply click on it and save the file.
Feb 14, 2012 | Audio Players & Recorders
My ptouch isn't printing; after creating a label, when i press print, the tape comes out but nothing is on it.
Try a different tape. Usually, when the ink and label get screwed up it's time to trash it and start over, but you might just inspect the cartridge to make sure they are joining properly. If another tape works, there's your answer. If not, well 1180's aren't very expensive and our Brother store (Staples) has a sale on them every other week. Another heads up. If you have a Meijer's store nearby, they are stupid. They're selling black on white 12mm TZ tapes for $9.99. Go and buy them all :-)
Apr 21, 2011 | Brother P-Touch 1180 Label Printer
How do i change the tape on it?
This machine uses the Brother TZ tape, which is available in a variety of colors and three widths (1/4" (6mm), 3/8" (9mm) and 1/2" (12mm)). A TZ tape is supplied with this machine.
1 Press in on the rough area at the top end of the machine and fold open the back cover. Should be the exact process as loading batteries.
2 If a tape cassette is already installed, remove it by pulling it
straight up.
3 If the ink ribbon in the other tape cassette is loose, use your finger to wind the toothed wheel in the direction of the arrow on the cassette until there is no slack in the ribbon. Also, make sure that the end of the tape feeds under the tape guides. Note: If you are using a new tape cassette provided with a stopper, be sure to remove the stopper.
4 Insert the tape cassette firmly into the compartment, making sure that the entire back of the cassette contacts the bottom of the compartment. Note: When inserting a tape cassette, make sure that the inner ribbon does not catch on the corner of the metal guide.
5 Securely close the back cover, making sure that it snaps into place.
6 Feed the tape by holding down CODE and pressing PRINT once, and then push in the tape cutter lever to cut the tape.
You can also get a copy of the user's guide here.
Thank you for using FixYa! Don't forget to rate our service.
Feb 10, 2010 | Brother P-Touch 1180 Label Printer
Brother P-touch 1180 tape cartridge jammed
Man, that tape's a real b!%^ch. I just spent an hour figuring it out, so here ya go... In the center is a (larger that the rest) gray wheel, this is the "toner" take up reel. On the tape that's come out of the cassette, seperate the three layers, and start "reeling in" just the toner. (The laminate and label that have come out are just lost, no real hope for them) When you get close to the end of the toner, help it feed straight back in, and it will go all the way back in. You may have to hold on to the laminate and label so it doesn't try to follow the toner. once that done, it should look like the original cartridge, trim off the excess and you should be good to go.
Nov 13, 2009 | Brother P-Touch 1180 Label Printer
I'm on my second machine since December. Neither P-Touch would feed the white tape, the other layers bunch up inside the machine. Called Brother, and they were no help (indeed not much interested in my problem), except to suggest I clean the rollers with alcohol/q-tip. This action did result in the tape feeding, but not properly as I now get an unusable label strip with all three layers, and printing on the clear layer backed by black layer. POS if you ask me; it is going back to the store.
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
ERROR appears and won't print
What size tape are you using in the machine?  Some of the fonts won't work if you are using 1/4" tape.  It will say ERROR if you're asking it to print a larger size. This won't be a problem for you if you switch to 1/2" tape, or just use the two smallest font sizes.
Hope that helps!
Click the link above, select the model you have and download the manual (1180 is in the list).
Hope this helps.
Nov 11, 2008 | Brother P-Touch 1180 Label Printer
Won't print
My P-touch has the same issue. There is a U-shaped spring wire that pushes one of the rubber wheels so it presses the tape against the element that "writes" on the tape. A small piece of plastic that holds the spring in place broke off so the spring can't do it's thing. CA glue (superglue) would not work, I am trying to find a parts source now, it is easy enough to replace.
Aug 07, 2008 | Brother P-Touch 1180 Label Printer
Label Maker HELP!! Brother ptouch 1180
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Computers & Internet
Brother P-Touch 1180 Label Printer Logo
290 people viewed this question
James Cagle
James Cagle
Jim Keysor
