Question about U-Line Icemaker
Ice maker I have a model 95 U line. when I turn it on it starts up, fills with water, compressor suts down it dumps and refills, the motor on the cycle never stops going trhough this prosess, it never freezes it just keeps going around and around. I replaced the water valve and 3 switches, I think it it in the control board switch taht stops the motor froom the cycles but I can not find this part. What do I do
Www.u-lineservice.com the main temp control or possibly a shorted mold heater. Not a DIY type of repair.
Posted on Jun 01, 2008
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Model KSBS25FK side by side--the ice maker not making any ice
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Oct 11, 2010 | KitchenAid KSBS25FK Side by Side...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Ice Maker does not dump ice
IF THE ICEMAKER IS TURNING AND NOT DUMPING YOU NEED TO REPLACE THE ICEMAKER ***.
Jan 12, 2010 | Samsung Refrigerators
No water going into ice box of icemaker. Motor seems to be working ok. Checked hose not snagged.
Most times that will be the water control valve on the rear of refrigerator and most times they come as a pair or dual one side for water dispenser and other side for the ice maker. You can test to see if the ice maker is defective by turning switch on and fill with tap water. When it freezes and dumps but no water refills the ice maker then the valve for the ice maker side is defective and will need to be replaced as a pair. If you fill ice maker with water and it freezes and then does not dump then most likely the ice maker is defective.Thnks Sea Breeze
Dec 13, 2009 | Samsung RS2534 Side by Side Refrigerator
No ice Ice maker does not fill up with water
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then check the fill tube going to the ice maker , to see if it is frozen up inside . If it is , replace the water valve behind the refrig , where the wall water line connects to on the refrig . If the ice maker dumps the cubes , but does not refill with water , then the water valve is bad . If the ice maker does not dump the cubes , then replace the ice maker .
Nov 11, 2009 | Refrigerators
I just replaced ice maker assembly because of broken plastic which holds drive gear. Now the new ice maker will not fill up with water. Water dispenser works fine.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 02, 2009 | Refrigerators
Ice maker won't send water to unit. Solenoid is good
Make sure the fill tube where the water goes into the ice mold is not full of ice. Your old valve may have been leaking and it will freeze in the fill tube. Other than than maybe start the ice maker working by filling it with water and see if it dumps and refills.
You can swap the wires on the inlet valves and try the water dispenser. The water should go to the ice maker letting you know the valve works and the line is clear.
Aug 15, 2009 | Refrigerators
U-line 95 ice maker
This problem is due to the timer motor in the faceplate of the icemaker. Replace the faceplate part #150 and that should takecare of your problem
May 12, 2008 | U-Line Icemaker
Model 95 Icemaker no ice
The cycle starts when you turn the icemaker on. It starts the dump cycle when the compressor turns off. The mold heater turns on and the cycle motor stalls until the ice cubes release and lets the moror complete its cycle. Then the compressor starts to repeat the cycle. If the mold heater is bad (it should read about 80-85 ohms) it will not dump all the ice and the mold will overflow on the next fill part of the cycle. If the over temperature switch is bad (checks open) It will not let the mold heaters work. The over temperature switch should NEVER open. If it IS open the mold heaters will not heat. MDB
Dec 04, 2007 | U-Line Icemaker
U-Line Icemaker Logo
102 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
