Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
The ice maker stopped working. It doesn't seem to be filling with water.
    Champion:
  • 210 Answers
Does the water dispenser work?
Posted on Jul 22, 2008
GE Profile Model PSS26LGSC Ice maker not working
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
Apr 07, 2013 | GE Refrigerators
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Sep 18, 2011 | Refrigerators
Ice maker has stopped making ice. Infa-red light on inside doesn't seem to be working
One of the causes of ice maker not producing ice is a bad solenoid valve allowing water to pass by and causing the water line to freeze inside the freezer. In other words, if the valve is not holding very well, it will allow water to pass in the line that supplies water to the ice maker. A small drip will ensue and slowly freeze in the line and eventually turn into an ice plug that will prevent water from filling the ice tray. Thawing out the freezer will not solve the problem, you will have to replace the solenoid valve.
P.S.Test the solenoid valve coil and disconnect the line from the valve to verify that it is not allowing water to pass when not energized. Test the infra red module according the manufacturer's instructions if you have them at hand. If the solenoid valve is good and the infrared sensor system is bad , replace it (Infrared system) . The ice maker should be the last part to consider for replacement at this time.
May 06, 2011 | Refrigerators
We installed a new subzero side by side 2 years ago and have had problems with the icemake off and on. Now it doesn't make ice and the appliance center does not seem to be able to fix it. The have...
did they check the water valve?does it fill with water?all it does is the ice maker calls for water,the valve fills it,the water freezes,the cubes dump out and it fills again,most of the time it's either the ice maker or the water valve,if they changed the ice maker and the board all that's left is the valve or a broken wire somewhere in the ice maker harness
Feb 11, 2011 | Refrigerators
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Water wont go all the way into the ice maker
Or
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Oct 08, 2009 | Kenmore Refrigerators
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
LG Ice maker
I got the same problem where the plate is cold and the water does not fill - saw this comment from other posting and help. Basically, the ice maker was stalled! Make sure you can see the green light is on, which means you have power. if its lit, press and hold the cube size button until i/m starts to cycle. If i/m runs, but does not fill then your water valve is bad. If i/m will not start then your i/m is at fault.
Dec 05, 2008 | LG LFX25960ST Stainless Steel French Door...
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
