Question about LG 32LC7DC 32 in. LCD HDTV
New 42LG30 - 42
My new LG 42" LCD TV is making a buzzing sound that has become really annoying. It started a couple of days after I got it. The only way that I've figured out how to reduce the noise is by turning the backlight all the way up to 100. Even after doing this it still hums when the screen goes all black.
Is this a common problem with LG LCD TV's? Should I return the TV and get a new one, or is there a way to fix this?
Please let me know as soon as possible
  • LG Master
  • 1,587 Answers
This is probably a defect in the backlight inverter circuit. The transformer may have a loose winding or something in there is not cycling off or on properly. If you can still collect on the warranty, do so.
Posted on Dec 13, 2008
Tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
LG LCD TV - Buzzing Sound and Faint Horizontal Lines
From your description, the sound you are hearing is the inverter(s) that drive the back light for the LCD screen/module.
The inverters mounted on the back side (one lower right and one left side) of the LCD screen/module. They are under the sheet metal cover/shields.
The inverters are going out and or the LCD screen/module is going bad too.
That LG TV has only a 1 year on parts and labor from the date of purchase, but you could call LG and ask for their help for such a new TV. They might do it under a warranty, for little or no cost to you.
I hope this information has helped you.
Good Luck.
May 23, 2010 | LG 47LG70 42 in. LCD TV
Rca l26wd14 buzzing
Hi!
I have seen this before in a lcd tv I worked on! My problem was some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). But also check the signal board (rca s-video etc... inputs). My thought in this was a bad cap was producing a harmonic, causing the speakers to squeal! Good luck, I hope this is helpful!
Mar 02, 2009 | Samsung LN32A540 32 in. LCD HDTV
Phillips 32" LCD TV, Sound through TV speakers has a buzzing noise which is steadily getting more aNNOYING AND LOUDER.
We are having the "buzz" problem with our new 42' Phillips LCD too.
We do not have a sound system yet...but have read they have the same problem, so I won't assume when I get a sound system it will go away. What I did do for now...and it helped..
Go to the SOUND portion of TV menu
Choose EQUALIZER
Turn down the two FAR RIGHT columns, they are the treble. It helped us.
Aug 26, 2008 | Televison & Video
Magnavox 50MF231D/37 Plasma tv
The plasma panel in most cases exceeds the cost of replacing the TV. There is also the issue that they tend to use different versions and makes of panels in these sets. Some panels are made by Samsung and some are made by LG. I would start shopping for a replacement TV at this point.
Feb 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung LN-T3253H LCD Sound Problems
PEOPLE, YOU NEED TO GO BACK TO THE STORE, BUY THE SAME TV AGAIN, SWAP THE TV'S AT HOME AND RETURN THE "OLD" TV IN THE "NEW" BOX WITH THE NEW RECEIPT. IN THE CASE OF TOO MANY RETURNS, HAVE A FRIEND, MOM, DAD, SISTER, GIRLFRIEND TO BUY ONE FOR YOU AND DO THE SWAP LATER.
NOTE: I REALLY HATE DOING THIS TO THE STORES, BUT IF YOU PAY FOR SOMETHING IT SHOULD LAST LONGER THAN 30-40 DAYS. PROBLEM SOLVED! :)
Dec 10, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
LG LC55 humming/buzzing
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Nov 24, 2007 | LG 42PC5D Television
LG 32LC7DC 32 in. LCD HDTV Logo
484 people viewed this question
Computer Repairing
Computer Repairing
