Question about Compaq Presario 700 470024-192 Notebook
Copier Scanner What kind of a copier /scanner can I buy for my 5 year old compaq presario computer?
    Genius:
  • 1,066 Answers
windows xp, yes. just look for printers which support windows xp.
you may have to upgrade your ram, but many hp machines (as well as other brands) will support pentium II's (10 year old technology) as long as they have 128megs of ram and a usb port. you may also have to update internet explorer (prolly to register the new printer).
the hardware interface matters only when it comes to printer port v/s usb, and most laptops and printers made in the last 5 years will all support usb. make sure the printer does not specify usb 2.0 in its minimum requirements, as this is a fairly new usb standard which was not around 5 years ago.
otherwise, make sure your laptop supports the other minimum requirements for the printer, as the printer's software may not load if the minimum requirements are not meant.
personally, i would recomend an hp, and a simple one at that; the more bells and whistles (such as flash card readers) the harsher the minimum requirements will be.
Posted on May 23, 2008
My computer clock is running fast... I figure it's the CMOS battery because it's almost 5 years old. It's a Compaq Presario SR1503WM Desktop. Which battery should I buy?
just u will remove the Cmos battery from your computers mother board and take it.
go to shop and ask like this battery i need.
then buy and replace it..
thank u sir... All The Best...
Apr 22, 2010 | HP Compaq Presario SR1503wm PC Desktop
I need to connect my lexmark x4270 to my computer
Did you get a driver CD with it? Just insert the CD and follow the instructions. If it is USB, do NOT connect your all-in-one until it is requested.
I hope this helps. Please let us know how it worked out for you.
Cheers,
TIH
Dec 30, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X5340 - All in One Printer/Scanner/Copier/Fax
Please follow the steps given below to add the scanner using Scanner and Camera wizard.
1. Plug your scanner into your computer.
2. If your scanner is "Plug and Play," the "Scanner and Camera Wizard" starts or double-click add device. Follow the instructions on your screen.
Note:
1. To open "Scanners and Cameras," click "Start," click "Control Panel," click "Printers and Other Hardware" and then click "Scanners and Cameras."
2. If you have a "Plug and Play" scanner, Windows detects it and installs it automatically.
3. If your scanner is not "Plug and Play," follow the installation instructions that came with the device.
4. If your scanner is not listed in the "Scanner and Camera Installation Wizard," try to install it using device manager.
5. After you install your scanner, you can test it.
Oct 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Scanner quit working on Dell AIO962
Apni ma mt chuudvao mujh se philips walo
Apr 29, 2009 | Dell 924 All-in-One InkJet Printer
Try to print--scanner failure appears
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Apr 17, 2009 | HP Office Equipment & Supplies
I would like to scan old pictures into a vista Word file.
Windows should install the device automatically when you plug it into the USB port. When you scan the picture it should transfer directly to "my picture".
Apr 08, 2009 | Computers & Internet
Pdf and jpeg format scanning problem in Canon iR2018 copier
Yes,you do have to buy the sent kit.But remember the sent kit Scan to e-mail and not directly to the computer.Your company have to have a mail server to be able to work properly.Adobe have software that you can buy that chance word document to PDF.
Feb 11, 2009 | Canon iR 2016i Black and White Copier
System error L3-00
L3-XX codes have to do with the scanner system. Most likely the scanner lock underneath the scanner (where the paper exits) got locked. It should be a round plastic knob. If that it not it you need to check the travel of the mirror system and lubricate the scanner rails. IF YOU DO NOT HAVE EXPERIENCE WITH OPTICAL SCANNER SYSTEMS DO NOT ATTEMPT TO REPAIR IT. IF THE CABLES SLIP OFF YOU ARE DONE. I've been a copier tech for five years and it took me four hours to restring the optics cable on a Kyocera and eliminate the skew.
Jun 05, 2008 | Sharp AL-1655CS Copier
Compaq Presario 700 470024-192 Notebook Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
