Question about RCA DISH Network(r) 311 Satellite System
Finding 110 (echo star 7) signal for dishnetwork.
I recently installed my dish on a viewsat extreme free to air.However I cannot get the 110 satelite.
I had my dish hooked up at a different location and all the cordinates was perfect,I didn't change any of them,it was installed level.I used a satelite finder,the receiver was set on a 119 channel,should I set the tv on a 110 channel to find the signal?.What's the purpose of using a switch?I think this looks like a splitter,should I connect both LNB and send one cable to my receiver.
Any advise out ther contact me @ lewissvg@hotmail.com
Thanks,
Jojn
5 Suggested Answers
satscoop
  • 59 Answers
SOURCE: Dish Network - Dish 500 Satellite 110 is not being recognized
Lonnie, You have a simple problem,the 119 satellite is lower in the sky than the 119 if you make sure the pole you are mounted on is straight and plum ,then simply raise the dish a few elevation degrees and turn the dish to the left.Your dish is aimed low and to the right.
Posted on Oct 29, 2007
SOURCE: dish network 119
you cannot satellite sginal from a splitter you will need dp 34 switch or quad LNBF DP HOPE THIS HELPS.
Posted on Feb 10, 2008
  • 2322 Answers
SOURCE: Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Posted on Feb 25, 2008
  • 51 Answers
SOURCE: satellite dish receiver error LNB Drift detected
actually both responses would be considered correct, except at this point with new software lnb drifts should no longer cause issues with receivers. lnb drift is a fluctuation of signal frequencies to the "crystal" in the feed horn. with current software ability to watch tv will not be effected by this
Posted on Aug 29, 2008
I have viewsat lite and i want to get it updated and new files to get access to dish on demand
nour09
DISH on Demand (also known as Video on Demand) is available to DISH Network customers with certain receiver models. Movies are downloaded automatically to the hard drive of the receiver, giving you the choice of which movies you would like to watch. I have provided a link to our Website, www.dishnetwork.com, with the requirements and movies available. I hope this helps.
http://www.dishnetwork.com/vod/default.aspx
Ray Calo
DISH Network
Feb 27, 2011 | Televison & Video
Hello- using dish 500 with twin lnbf, 311 receiver. 119 locked in easy with 70 signal . When trying to find 110, I cannot get a strong enough signal to lock. 129 signal shows strong along bottom of point...
Hi CharlieO my name is Mike of DISH Network and I was reading over your post and seenwhere your 110 satellite is not locking in or on your install summary screen. Iwould be more than happy to help with this issue and to research further I willneed to look at the account to look what satellites they have setup on youraccount. I will need your account number or your phone number; I will leave mye-mail so you can contact me directly. Michael.houston@dishnetwork.com
Jan 30, 2011 | RCA DISH Network(r) 311 Satellite System
How do you tune in tv channels when you only have a signal input from a satelite dish and no sky decoder. TV is a sharp lc-32l400x with built in freeview. Can we plug dish straight into TV aerial port...
You require a satelite decoder/receiver for your dish and an aerial for your TV.
The choice is yours. Plug a satelite receiver, for freesat, into the A/V input on the TV or have an aerial installed for freeview.
Jan 19, 2011 | Televison & Video
No signal on one tuner for dual tuner box.. neither tv works.
Hi benray there is something else youcan do on that to make sure your getting the strongest signal possible. Youwill need to press the MENU-6-1-1 buttons on the remote. Select Check Switchand Test, after the test is complete select done and then check the signal andif there is still a weak signal we will need to re-point the Dish.
Oct 24, 2009 | DISH Network 322 DTV Receiver
Fta viewsat 2000 setup problem
You will need a sonicview or viewsat switch spliter 110 port 1 119 port2 then go into your menu and ajust the settings 110 tp is 12258 and 119 is12239 and make sure you have the freq on the correct setting11250 scan each alone then save.Also set what typelnb you have on there to hope i helped
Dec 17, 2008 | Yamaha HTR-5730 Receiver
Viewsat ultra update doesn't help
You need to reaim your dish to echo 110 .You have it on bell and bell is down.Try reaim then factory set then rescan and make sure you have the right tp and freq settings freq is 12250 and tp is 12258 then autoscan exit when done and let it sit for 15 min on channel 500 cnn and it should work hope i gave you a fixya thanks :)
Oct 04, 2008 | Yamaha HTR-5730 Receiver
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Sep 04, 2008 | DISH Network 301 DTV Receiver
Missing cjannels
sounds as if your dish as slitly gone of line the dish needs resetting
Jan 27, 2008 | RCA DTC210 DirecTV DTV Receiver
Televison & Video Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
