Question about Jabra BT150 Wireless Headset
Connect jabra to blackberry
How would I connect my jabra bluetoothe to my BB Curve?
  • 679 Answers
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT150 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
SOURCE:
How to pair my bb curve to uniden BT112 bkuetooth
You need to put the bluetooth into pairing mode.
Jun 26, 2012 | Blackberry Curve 8350i
Music player through my bluetooth
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
michaelvincentc
Dec 25, 2011 | Jabra BT2080 Bluetooth Headset
I purchased a Jabra bluetooth that fits on the sun visor how do I connect with my black berry
Go to options menu on BB bb_icon.gif and locate Bluetooth.
- Enable Bluetooth.
- Then turn on Jabra 250 and Hold down the Multi-Function Button until you have a SOLID BLUE LIGHT on the LED on the headset. This could take up to 10 seconds and will take place after the LED has ceased to flash.
- Click add device on your BB.
- BB will search for your earpiece. 0000 is your passkey to add device
Jan 15, 2011 | Jabra Cruiser InCar Speakerphone Black
My BB Curve 8520 does not connect via Bluetooth with the Jabra Cruiser2. After a very first succesful connection it won't connect anymore. Same problem with my Ford Radio (Galaxy2007). It works with other...
Hello fra pala... Since it is new, it is entirely possible that you got a lemon and will have to return it to the store. This happened to me just last month. That said, here is an excellent link that may be the solution to your issue. Joe
http://www.blackberrycool.com/2009/08/10/the-blackberry-curve-8520-setup-guide-and-tips-and-tricks/
Thanks for choosing Fixya!
Dec 05, 2010 | Cell Phones
Unable to pair Jabra 5050 with Motorola qa1. Bluetooth is on in both devices, unable to find device from QA1 or from BB.
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Dec 14, 2009 | Jabra SP5050 Bluetooth Headset
How to connect jabra BT150 to blackberry 8520 curve
You need to pair your Blackberry with your headset.
  1. Turn on your Blackberry's bluetooth and search for bluetooth devices.
  2. While the Blackberry is searching and the headset is off, press and hold the call/end button on the headset until it's light glows steadily. Do not let go until the Blackberry finds it.
  3. Pair the devices and allow the headset to connect automatically.
  4. Default passkey is 0000.
  5. To connect, press and hold call/end button on headset like the one in step 2.
Oct 29, 2009 | Jabra BT150 Wireless Headset
Trying to connect Jabra BT135 Bluetooth Headset to Blackberry Curve 8900
Oct 13, 2009 | Jabra BT135 Bluetooth Headset
Igave been using my Verizon Jabra VBT185Z
where can I find the setting on my Blackberry Curve to pair my Jabra VBT185z
Jun 20, 2009 | Jabra BT350 Bluetooth Headset Headset
Pairing Jabra BT4051 to my blackberry
I paired my BT4051 with my BB curve just fine. I held down the power button on the Jabra until the blue light was solid and then added the device through my BB's bluetooth setup under options.
Jan 17, 2009 | Cell Phones
Jabra BT150 Wireless Headset Logo
2,469 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
