Question about Epson Stylus CX9400 Photo Printer
Have an eson stylus cx9400F
Everything is hooked up. I just changed the ink cartridge, I cleanded the nozzle head, and the more I clean the printer nozzle head, ink starts to go lower and lower. Another problem is when I "hit" print, there are some sheets with blurry prints on it and some sheets with blank print on it. What is the problem? Please help me out with this. Thank you.
    Problem Solver:
  • 6 Answers
Every time you do a nozzle clean routine in an inkjet printer, like the Epson CX9400Fax, ink is wasted. When it is $20.00 for a quarter ounce, that is wasteful to your wallet too. The nozzle head cleaning routine flushes your ink from the cartridge through a tube to the nozzle, where it mostens the nearly microscopic holes and flushes hardened ink residue away.
The wasted ink from machines often goes through a rubber gasket or wiper, and into a large, thick felt pad, maybe an inch thick, hidden deep inside, near the bottom of the printer, where it eventually soaks in and dries. In some machines, this happens every time you start the printer, so it makes sense to keep it plugged in. Each cartridge uses some ink, even if you only use it for black and white, so you pay a lot for something you don't even use.
Unfortunately, HP and Epson abuse the trust that users put in them. Word is that HP makes more money on cartridges than it does in printers and plotters. This leads to poor printer design that makes it impossible to refill cartridges, get 3rd party cartridges, or use a printer for black and white and not waste color ink.
Posted on Aug 11, 2008
  • WonderWheele Aug 11, 2008
    If you find the inkjet head, and wipe it gently with a q-tip or something, that might help get rid of residue that otherwise is wiped onto the paper. I haven't looked inside my machine to see how to get to the area, so am not sure. On some HP printers, the printhead is part of the cartridge, but that is not the case with this printer. This printer just has a rubber opening on the bottom of each cartridge almost 1/8" in diameter where the ink comes out into the plumbing system of the printer.
    Sorry for the long editorial earlier, but I needed to vent as I bought one of these printers off Craig's list yesterday for $60.00 and realize it was a bad investment.
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Changed from cartridges to cont. ink system. Now
Hi Dave,
Chances are the problem is that you haven't removed the travel plugs that allow air into the reservoir part of your CIS. This is vital because the air needs to replace ink used up in printing and if it can't do this the air creates something of a vacuum that holds back the ink.
Also worth checking that you haven't got any crimped (folded) tubing or clamps that are still engaged that shouldn't be.
Hope that helps..
Mar 26, 2010 | Epson Stylus Photo 2100 InkJet Printer
I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Jan 13, 2010 | Epson Stylus C46 InkJet Printer
How to change the cartridge
head clean, then nozzle check then head clean again until the nozzle check pattern looks right. If you get no ink at all by three clean cycles change the cartridge again
Jan 08, 2010 | Epson Stylus NX400 InkJet Printer
Yellow cartridge stopped workin halfway through a document although nearly full
Hi, one or two head cleans won't clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
The magenta ink won't print & it's not the cartridge
Hi, one or two head cleans won't clear a clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
Others are available just try googling "inkjet head cleaning". The nozzles on the print heads are finer than a human hair, even if you could get at them without a major strip down I wpouldnt recommend it as they can easily be damaged.
Apr 07, 2009 | Epson Stylus C66 Photo InkJet Printer
Not printing magenta ink and tried cleaning heads already
Mar 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Ink printing problem
Did you remove the plastic from the bottom ofthe cartridge, if not do so and changing from vista to xp would change that probelm.
Jamiell
May 13, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus CX9400 Photo Printer Logo
283 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
