Question about Navman PiN 570 GPS Receiver
Charging socket on navman pin 570 has come out
The charging socket in my pda has come out
  • 1 more comment
  • jimbok0151 May 19, 2008
    can anyone tell me how to repair my navman pin 570 the charging socket has come out and i have got the plug in part any advice would be nice thanks
  • wenliag Jun 05, 2008
    Also the same thing has happened to my Navman PiN 570. How do you fix this socket back into navman or is their a repairer anyone can recommend to do this. I live in New Zealand and would appreciate any help
  • Ev Coates
    Ev Coates Dec 10, 2008
    the thing is one of my pins is broken of and keep trying to find someone who may just sell the pins no luck yet
These sockets are on sale if you google enough. Ebay seller totalviews for example. Check its the right socket and be prepared for very small presise soldering. when you open the case, take great care not to break/dismantle the rocker switch that protrudes as it has minute elements in it. If charging is a problem but the socket appears sound,m check the plug that goes into it and ensure the springs go in and out to hold it in place.F4therchristmas
Posted on Dec 13, 2008
Kinda the same with me but mine stopped charging so brought a new battery plugged it in but still wont charge.
Called Navman here in NZ and they said its probably the socket (which in my opinon has got to be THE most stupidist plug EVER) and because they dont make it anymore only option is to upgrade to another unit (GPS only)
So Im going to have a go at pulling out the socket and having a go myself.
Give me you email and Ill let you know what happens
Posted on Jun 20, 2008
Broken lcd on Pin 570
The screen is expensive in relation to the value of the pda so a practical solution is to buy a donor pda with a different fault being offered cheaply for spares. The screen is the same as that for the Acer N35. Both PDA's are based on the same motherboard although they are not interchangeable due to slightly different fittings for example the GPS aerial connector. Screens and batteries are interchangeable.Try Ebay or Trade Me. If the ribbon is not pushed home firmly and square before locking in, it will not work and swicth on and off and on to check. You need a certain amount of good fortune when buying a dead donor as any other fault may disguise the fact that the donor's screen may also be kaput!
Jun 20, 2009 | Navman PiN 570 GPS Receiver
Pin navman handhelp pc will not work off battery
Try holding soft reset for a couple of minutes whilst charging. If this does not work leave pda charging with hard reset switched off BUT all data will be lost. Then move hard rest and if you are lucky the green charging light will start flashing and you can switch on. It sounds as though you have flat battery and if left too long restarting becomes very difficult as the motherboard cannot start the recharging process while the pda is switched on. This is true even with new batteries which can be supplied flat if old stock.
Even liquid damage is unlikely as there are so few exposed connectors. I have not tried it but gently drying motherboard with a hair drier on gentle setting and cleaning battery connector and screen ribbon cable before assmbling might work. Treat both connectors as being etremely fragile although they are more robust than you might think. But treat them with extreme care as repairs to them would be more expensive than the value of a working pda.
Jun 09, 2009 | Navman PiN 570 GPS Receiver
Navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
May 28, 2009 | Navman PiN 570 GPS Receiver
Pocket pc navman 1022 charger and charger jack pin
sir, i have pocket pc 1022 navman pin 570 is not connecting with my pc.
May 16, 2009 | Navman PiN 570 GPS Receiver
Charging socket has come out
DOnt know where you can get it fixed but I "hard wired" it so it has now become a GPS only.
What a stupid plug they came up with (so much for supporting Kiwi made)
The amount of stress that is placed on the plug while its pllugged in and your driving,something has to give sooner or later.
Jun 05, 2008 | Navman PiN 570 GPS Receiver
Pin 570
Start Here:
http://www.navman.com/
Then select your region. They have an online store to buy whatever you need.
Cheer mate,
Worldvet
May 24, 2008 | Navman PiN 570 GPS Receiver
Navman pin 570 pocket pc will not charge
It is likely your battery is depleted or it can also be an unlikely flaw in the firmware.
To eliminate the firmware flaw, restore (flash) the entire firmware using a downloaded version from the Navman.com site or an upgrade of the OS and or GPS app which will likely include an entirely new firmware.
Since your battery isn't retaining a charge, this operation should be performed from a PC demonstrated to provide power to the PiN 570 and or a reliable power strip on a UPS if you're using the split AC/USB cable.
A device subjected to a power interruption during a firmware flash can become permanently ruined or cost ineffective to recover.
Mar 22, 2008 | Computers & Internet
NAVMAN 570 PIN
maybe there is a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board
Jan 23, 2008 | Navman PiN 570 GPS Receiver
Cant get the menu display on my pin 570
maybe there is no memory caused by a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board.
Dec 03, 2007 | Navman PiN 570 GPS Receiver
Not responding......help
Low or flat battery. Connect to mains charger and fully charge.
May 27, 2007 | Navman PiN 570 GPS Receiver
Navman PiN 570 GPS Receiver Logo
292 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
