Question about Hitachi RAS-09UH Air Conditioner
Wont work just installed hitachi split and self diagnostic indicator say problem with thermistor defective . how do we fix . cheeers
    Problem Solver:
  • 5 Answers
Simply you just replace thermistor in order to activate your unit.
Posted on Jan 26, 2009
I have a sharp ar m335n copier with error code h2-01 how do i fix it?
Thermistor open detected. Thermistor defect
MCU PWB defect
Fusing section connector contact
failure
Power supply failure
Fusing unit not installed
on
Check the harness and the
connector of the thermistor and
the MCU.
Clear the self diag display with
SIM 14.
Jun 24, 2014 | Sharp AR-5316 Advanced Digital Imager...
CALL FOR SERVICE CODE H4-20
Possible causes for this are:
Thermistor defect
Heater lamp failure
Thermostat failure
Control PWB failure
Try the following remedies:
Check the heater lamp blinking with SIM 5- 2. When the lamp blinks normally:
Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light:
Check for disconnection of the heater lamp and thermostat.
Check the interlock switch.
Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
To enter self-diagnostics mode press the following # * C *
Feb 09, 2014 | Sharp AR-M237 Digital Copier
Hello. I have a hitachi hdt721025sla380 on my compaq presario. My diagnostics keep saying that it is not working correctly. so, when I try to boot up my system, I get what people seem to call "the...
It could well be that your HDD has died, indications thus far indicate so.
The only real fix is replacing it and re-installing your operating system however, if you can extract it and connect it to another PC, you may be able to run some diagnostic software against it to see if it can be repaired or data recovered.
Here's a url to a couple of free tools :- http://www.filehippo.com/search?q=hdd+diagnostic+
Jun 25, 2011 | Hitachi HDT721025SLA380 250 GB SATA Hard...
2002 Ford F150. Cruise control stopped working.
Did you have the recall done on it ?
recall 05S28. Description: Speed Control Deactivation Switch.
It could be a blow fuse in the recall harness, if you did have it done.
Try the self test, and see what the results are. If you do not get it into self test mode, it could be the fuse in teh recall harness that is blown. The 1st revision of the recall harness was an inline ATM fuse, not sure if the revision 2 was the same. If that fuse is blown, the switch is leaking, and should be checked.
Self-Test Diagnostics
WARNING:
This test is a key on engine off (KOEO) test only that is conducted in park only with emergency brake fully engaged.
1. Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
2. Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
Note:
There will be a slight delay when the last button is pressed and the lamp flashes.
3. A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
— 2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
Feb 22, 2010 | 2002 Ford F150 Regular Cab
H 2 -d-ont work
H2 indicates a problem with the thermistor/s open in the fuser.
You can check the wires leading from the board to the thermistors..
Use SIM 14 to clear the self diagnostic display..
Oct 16, 2009 | Toshiba e-Studio 161 Copier Copier
Air conditioner
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit. The resistance of both thermistor is 8 to 10k ohms, so can test by using ohm meter
Jan 12, 2008 | LG LSC121PMA Split System Air Conditioner
Art cool keeps stopping
Try to unplug the unit or “off” after 10sec. “on” the circuit breaker and then start the unit.
But if the defect persist then you need a qualified technician. The below error may be the cause of unit failure.
- Out of range thermistor is also can also be the cause of tripping outdoor unit with matching blinking light same as low refrigerant.
- Dirty indoor and outdoor can also be the cause
- If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
Dec 26, 2007 | Heating & Cooling
Dryer
Error codes. are any of these lit? PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Kenmore 82836 Gas Dryer
Hitachi RAS-09UH Air Conditioner Logo
112 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
