Question about Philips 42PF9630A 42 in. Plasma Television
Phillips Plasma Error
Hi -
Saw one of your posts and thoguht you might have an answer to a problem I'm having - I turn the set on and when it powers up I get sound but no picture. A second or two later the set suts itself off and a red LED on the front flashes six times slowly, then three times quickly. Any ideas?
  • 138 Answers
Replace the SSB the error is the VIPER and that is a chip located on the SSB.
Posted on Aug 19, 2008
  • 53 Answers
Firmware update via USB stick downloaded from Philips.
44hink
Posted on Jun 04, 2008
Philips Plamsa won't turn on, has a black screen but the power light is on. There is also a constant clicking noise.
mine has begun to do the same thing @ first it would click for a few min and eventually it would come on and until we turned it off again it would work great. Today however when I accidently turned it off before bed I didn't think anything about it I just figured when I woke up i would have to go thru the whole clicking process and it would come on. Unfortunatly today has been different so I searched online and found a few answers and I am gonna try to fix the problem myself if I accomplish fixing it I will post how. I have also come to a conclusion about Phillips TVs.... I will never purchase another one I am fixing to call them and see if they are @ all helpful and if I get "this is basic wear and tear after many people havr posted the same complaint about the same model number I will have a few words for them also. I know for myself I can't afford to go purchase a replacement when we bought this TV it was a Christmas gift that me and my husband gave to our selves with our income tax return now we have both losed our jobs and there is no way to afford such a luxurary. Not sure if u saw the same post I did but look up ur model # and search Phillips Plasma plus model # and use the word clicking and you should locate the postings I did. Hope this helps somewhat.
Jan 11, 2011 | Philips 42PFP5332D 42 in. Plasma...
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
50 inch phillips plasma is very difficult to turn on.
hi sounds like a power supply fault, swollen capacitors usually cause this fault,thanks
shaun
Mar 15, 2017 | Televison & Video
Set dosen't power on/off.
Replace the small signal board 310432842611.
Oct 02, 2008 | Philips 42PF9630A 42 in. Plasma Television
Phillips plasma problem
I have the service person coming Thursday to look at the same problem. Will let you know outcome.
Aug 03, 2008 | Philips TV Tuner Video Capture PCI Card -...
Plasma e01 error
Hi. Had all the symptoms with my Pioneer 43" plasma with RO3E receiver that have been previously posted. I got so fed up with it turning itself off that i decided to take the top off the receiver and look for the dry solder joints on the power supply board that some have posted to have cured the problem. I removed the power supply board (which involved removing an interface unit which is mounted above it) and found no issues. I then proceeded to remove the switch board which is placed in front of the power supply board. When i removed the electrical connector which i found not to be fully inserted, i noticed that there was a brown burnt stain in the middle of the connector plug indicating a possible poor connection. I removed the electrical connector from the unit completely (the other end connects to the adjacent board with the fuse on it) and cleaned the connector plug with electrical cleaner and re-inserted it into the receiver and built everything back up. I am happy to report that the tv starts up first time every time and has not turned itself off since. I have included a picture of the offending plug in its built up state (it is the one with the row of black wires with one red wire). Do not attempt to do this unless you are suitably qualified.
Jun 09, 2008 | Pioneer PureVision PDP-503HDE 50 in....
Philips 42PF9630A 42 in. Plasma Television Logo
113 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
