Question about Sanyo VWM-800 VHS VCR
Recording i want to record a tv show while i am out what channel do i set the vcr to and what do i set the tv to the channel i want to record is 15
  • 28 Answers
You should set the VCR to the channel which you want to record. It doesn't matter what channel the TV is on. In your case, just turn off the TV.
I making assumptions about your setup. If you can turn on your VCR and TV and watch the channel that you will be recording, then just turn your TV off, and you should be good.
Only caveat, some VCRs must be turned off while waiting for the recording timer to activate (presumably, so as not to interfere with someone actively watching a program).
Posted on May 19, 2008
4 Suggested Answers
  • 152 Answers
SOURCE: I am having trouble channel setting and recording.
If you have a bad or fuzzy picture when viewing tapes on VCR then you need a new video drum. I think you can buy another that is for your brand on the internet. More VCR Repair -
Posted on Jun 07, 2008
  • 1148 Answers
SOURCE: i cant record tv through my vcr.
set the vcr up so that you change the chanels through the vcr,,,check the vcr setup menu
Posted on May 17, 2009
  • 3 Answers
SOURCE: VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Posted on Mar 01, 2010
I have a hdtv with digital channels. I also have a vcr that can record shows. The thing is i have everything set up correctly. How do i record the shows on tv to my vcr?
A VCR will not record HDTV signals. You can only record normal digital signals. If you wish to record HDTV channels you should look at Blue Ray Recorders.
Sep 28, 2013 | Televison & Video
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
Taping to vhs from digital cable
You do not need to leave the TV on. To get the clearest picture you should connect the AV cables (yellow, white, red) from the cable box to the VCR, and from the VCR to the TV. There should be a setting on both the TV and the VCR to set the input to VIDEO so you don't have to use channel 3. You can shut the TV off while recording if you want. Also be careful because if you use the channel guide or info button while recording, it will show up on the tape.
May 20, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Apr 19, 2009 | Philips Magnavox DVD/VCR Dual Player
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Vcr will not record
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
RCA VR355 recording problem
Are you sure the reciever is coming through the vcr.? are you hooking it up through a/v on vcr?
if so hook from a/v out from directv to a/v in
jacks on back of vcr. and turn vcr on a/v channel
to record it. you will see the picture as you record it. if the vcr isn't on a/v channel it won't record it
If you use ch 4 or 3 to record it you
hook up directv to cable in on vcr and you
have to turn vcr on that channel and see it coming
through it you have to push a button on satlette
remote to make it come on the vcr on the channel
or it will record snow. and you have to push
another button on vcr remote if you haven't
already to get the vcr on ch 4 or 3 on your tv
or if u got it through a/v turn tv to a/v channnel.
just beacuse you see the picture coming through
your tv doesn't mean it going through your vcr
you could be just seeing it through the tv only.
you will see the vcrs graphics or vcr channel number on your
tv too along with the directv channel if it's hooked
up right. notice the vcr won't record it's own
graphics or channel number on the screen but it will record the directv's graphics. and it won't record the tv's own grapic channel number either.
to make sure it's right you will see 3 graphics on
your tv the own tv's channel number or a/v
the directvs and the vcr's channel number or a/v
on your tv if you see these you know it's hook up
Nov 11, 2007 | RCA VR355 VHS VCR
Sanyo VWM-800 VHS VCR Logo
217 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
